A different drabar lock solution
/ A different drabar lock solution #1
briancd
Bruce Peninsula, ON, Canada
NH TC26DA
Hello all;
One of the first "implements" I bought for my new CUT (spring 2006) was a 7 hole drawbar. I am absolutely a newbie but when I saw the drawbar for $20 at TSC I knew it was just what I needed to pull my (max GVW) 1500lb trailer around the property. When I put it between the 3ph arms all seemed well until I I put the trailer on the ball and the whole thing swung upside down. I know this is a common problem because I looked for solutions and found that several of you have welded together drawbar locks or bought them at TSC. Well, I don't weld (yet...and please let's not start on the thread about "a guy with a tractor that doesn't weld????") and the TSC here had never heard of a drawbar lock, nor had my NH dealer where I bought the tractor. So I'd tried some things with stock angle brackets but they all bent out of shape quickly. Last week I was at my dealers and saw this U-bolt that looked about the right size. It was $16. I bought it on a chance...
The 3ph bar was about 1/16" too wide to fit in the "U" (see pics) so I had to angle grind a bit off the inside surface of the U-bolt, but other than that it worked great!
I just thought I'd share this in case anyone else was looking for a drawbar lock but didn't have access to the "real thing".
Gee, it's seems you can't edit the title of threads, so I apologize to all for my "drawbar" typo!
/ A different drabar lock solution #3
I bought the TSC drawbar too. I have my neighbor, a welder (I don't weld either!) making it into one of those complete units that also attaches to the top link. He made one for himself and offered to make me one if I bought the bar. When it is ready I will post pics for anyone who wants to do the same thing. He has enough scrap steel laying around that it isn't costing anything but the $22 or so the drawbar cost. Of course I will get him a gift card or something for doing it.
/ A different drabar lock solution #4
briancd said:
...the TSC here had never heard of a drawbar lock, nor had my NH dealer where I bought the tractor.
Tractor Supply Company - DRAWBAR LOCK
Don't know how well that link will work but TSC # 1000786 is a drawbar lock that lists for $15.24 on the website. The problem I found with it was, although described as a Cat 1, the one in the local store with the TSC# 1000786 identification was dimensionally for a Cat 2 drawbar and hitch. I'm still looking and may wind up building my own. That might be my first project after I teach myself how to weld.
BTW, Briancd, using a clevis like that is a pretty ingenious solution.
/ A different drabar lock solution #5
Brinecd I think you have a very good and simple solution there. The only thing is the nomenclature of the u-bolt. I think it is called a clevis
Hi Tom and CF, thanks for the fix on my terminology... now I know what a clevis is!
/ A different drabar lock solution #8
Not only that, but it seems that I can't edit my posts at all after about one day. Of the boards I frequent this is my first experience with loosing the ability to edit my own posts based on time. Not sure what the reasoning is behind that.
/ A different drabar lock solution #9
its a setting in the new board softwere they are useing. they could change if a) they chose to and b) new how to...
as well as the quick reply at the bottom. "they" were advised to not use it, but only because they got bad advise. The other board im on a lot also upgraded to the same version and we went through the same thing about no quick reply. Turns out they figured out "how to make it work"
see posts #17-20 over hear Give us a list of broken things here - YotaTech Forums
/ A different drabar lock solution #10
I bought a locking bracket from an independent dealer- I think it was about $20.00- works great-The brackets are out there, but I like the clevis solution too. I will try to post a picture- if the weather clears up. Rain, Rain,Rain- Go Away!
/ A different drabar lock solution #11
No criticism to you.. however.. i gotta say.. you got a pretty pi** poor CNH dealer and TSC dealer. Both list drawbar locks. in fact.. the CNH dealer also sells a kit to tun a drawbar into an 'A' frame to use the toplink on.. sells for 20-30$ down here in florida.
I think i'd write a letter to the regional manager at TSC and ask him why his sales people are not trying to sell products their store carries or can order.. Isn't that counter productive to a retail mind set? or are they actually there to -not- make money., ( I did this with a tsc regional manager down here before, after a few of his stores were playing -dumb-.. he was quite emvbarrised, and there were some management changes quite soon after that.. ) and also put in a call / letter to CNH corporate and as them why their dealer aren't training their counter people considering you, as a customer, bought one of their expensive blue tractors.
Your clevis idea should work fairly well in the mean time.
Soundguy
briancd said:
Hello all;
1998 International Loral (A64126)
1998 International...
John Deere Forks (A64126)
John Deere Forks...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
2008 GMC 3500 HD 4x4 Ext. Cab 9Ft. Flatbed Truck (A64194)
2008 GMC 3500 HD...
Landhonor Skid Steer 3Pt Hitch Adapter (A62679)
Landhonor Skid...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
