A couple things I noticed underneath my GC1710
   / A couple things I noticed underneath my GC1710 #41
GeneV, my tractor is at my other property so unfortunately I can not run out and look I need to do it when I go out there to do things but with age comes the forgetfulness and even if I write something down it is not a guarantee that I will remember the paper I wrote it down on hahaha.
If this rain ever stops and I get a chance to put my deck back on I will check it out hopefully.
Jim.
Lol no worries Jim, my memory is shot as well, even though I'm still a kid... trapped in a 47 y/o body.
   / A couple things I noticed underneath my GC1710 #43
As a pain as it was, I replaced the zerks with angled ones. What i noticed though, the right one ( as if you sitting in the seat ) should be lubricated as it does move slightly on the shaft. The left however is solid and from what i seen, needs no lube.
   / A couple things I noticed underneath my GC1710 #44
There is a solid shaft that raises/lowers MMM deck (or "other" mid mount implement) that pivots in those two collars with the offending ZERKS...
Dale
   / A couple things I noticed underneath my GC1710 #45
Yep went out and put that Piranha bar on and I forgot to take a look at the zerk yep everything is normal in my world hahaha.
Jim.
   / A couple things I noticed underneath my GC1710 #46
Yep went out and put that Piranha bar on and I forgot to take a look at the zerk yep everything is normal in my world hahaha. Jim.
"Piranha bar"..???? What is that? (Goggle doesn't know either)
BarnieTrk
BarnieTrk
   / A couple things I noticed underneath my GC1710 #48
Can not wait to get out today and try it for the first time, I will have before and after pics to come.
Jim.
P.S some pics are upside down but when tapped on show up normal, pics are taken the same way but just download goofy.
   / A couple things I noticed underneath my GC1710 #49
Imold, would you be able to get at it as is with a grease needle? Maybe. Would it be a hassle? Most definitely. With all them zerks to hit on the tractor, I'll take easy peasy lemon squeezy. :cool2:
I also found those zerks recently against the frame for the brake pedal. I was able to get a lock n lube onto it and grease moving through. I meant to post on here about the secret grease zero but never got around to it
   / A couple things I noticed underneath my GC1710 #50
Jim.
Because you smart phone does not really know where UP is....
Dale
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
Hydraulic Tree Sheers (A55272)
Hydraulic Tree...
2015 Chevrolet Express 2500 Passenger Van (A56858)
2015 Chevrolet...
2008 Ford F450 Lariat Pick Up (A55272)
2008 Ford F450...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
New/Unused 72inch Quick Attach Vibratory Roller (A57454)
New/Unused 72inch...
