A/C For Curtis Cab on JD 4300
   / A/C For Curtis Cab on JD 4300 #2
Re: [email]poppinjohnny@aol.com[/email]
Where are you located? It might be easier, if you are in a low humidity area, to rig up an evaporative cooler. No compressor or condenser that way.
   / A/C For Curtis Cab on JD 4300 #3
there is a thread on here somewhere about 12 volt air conditioners using a picnic cooler as the reservoir.
two styles were mentioned, evaporative [aka swamp cooler] and air conditioned type.
do a search for air conditioning
   / A/C For Curtis Cab on JD 4300 #4
Ithink a 12 volt air conditioner from an RV might be easily adaptable.
   / A/C For Curtis Cab on JD 4300 #5
I would check into the evaporators mentioned or I believe red dot brand makes after market air conditioning,a friend of mine has a JD 650 with cab and installed himself he swears buy the Red dot.
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
17201 (A55852)
17201 (A55852)
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
