A/C For Curtis Cab on JD 4300
   / A/C For Curtis Cab on JD 4300 #2
Re: [email]poppinjohnny@aol.com[/email]
Where are you located? It might be easier, if you are in a low humidity area, to rig up an evaporative cooler. No compressor or condenser that way.
   / A/C For Curtis Cab on JD 4300 #3
there is a thread on here somewhere about 12 volt air conditioners using a picnic cooler as the reservoir.
two styles were mentioned, evaporative [aka swamp cooler] and air conditioned type.
do a search for air conditioning
   / A/C For Curtis Cab on JD 4300 #4
Ithink a 12 volt air conditioner from an RV might be easily adaptable.
   / A/C For Curtis Cab on JD 4300 #5
I would check into the evaporators mentioned or I believe red dot brand makes after market air conditioning,a friend of mine has a JD 650 with cab and installed himself he swears buy the Red dot.
200387 (A51247)
200387 (A51247)
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2018 Autocar ACX Xpeditor T/A EZ-Pack Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
3ft 5-Point Metal Star (A55853)
3ft 5-Point Metal...
