9n temperature guage?
/ 9n temperature guage? #2
Why? Don't you have one?
If it never overheats, then you don't need one. But if it does, then the temp. guage may let you know in advance that overheating is going to happen.
No, there isnt one. There is an oil gage and a ammeter. And I dont see a plce where there was supposed to be one. And my point is to make sure it does not overheat. Not to run it until it overheats then say oops.
Ken H.
/ 9n temperature guage? #4
Neither of the N's.. ( 9 / 2 /8 ) had temp gauges. They do have thermostats that fit in the top radiator hose though. The cooling system for these engines is way over rated.. and will cool the engines very well, if in good working order.
The 8n had a pressurized system, while I believe the 9n and early 2n's didn't...
If you have a replacement radiator though, the cap will have been changed too.. The early non-psi ones had different locking lugs.
I've heard of people drilling and tapping for them, but havn't done it myself.
I'm not sure what size fitting the sending unit for the gauge is.. but i soppose if you didnt want to drill and tap you could remove the drain petcock on the side of the engine near the starter and install the sender.. or a t, and the sender and the drain plug...
Bottom line.. if you are boiling out coolant, clean that radiator inside and out, and change your coolant and the thermostat and see if that helps any.
Soundguy
When I was taking my test drive it was completely fine. Just curious as to when it hits 95 degress outside. I would like to be able to stop before it gets to the point of overheating... if it were to ever.
Thanks
Ken H.
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
2023 New Holland Procart 1428 Rake (A63688)
2023 New Holland...
Kubota MX6000 (A64126)
2022 EZ-GO ELITE...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
John Deere 1025R (A62177)
John Deere 1025R...
