9N steering
/ 9N steering #1
RobertN
Super Member
Shingle Springs California
New Holland TC40D
I brought my Dad's 9N home; the front wheels keep moving inward/toe in, sometimes in a matter of feet. I can straighten them out by hand. You can feel and hear, as though the teeth on the steering sectors are skipping.
Reading in the manual(FO-4), there is some adjustment by removing the steering wheel, and adjusting the steering shaft itself. It really feels like skipping teeth...
The odd thing, is the tie rod end at the sector shaft seems to be rubbing on the bellhousing. I wonder if the sector shaft arms are bent inward...
My Dad parked it a couple years ago. It is rough but ran good; don't foresee problems getting it running. Seems to be early 9N with the aluminum steering housing.
/ 9N steering #2
I bet the bushings are gone or worn, and now your gear set is too if it keeps slipping
/ 9N steering #3
Ditto what soundguy said. Also since your tractor is a '39/'40 model it will have the wedge bolts in the steering arms which will ware out and cause the knoch in the spindle to widen. You will see the head of the wedge bolt sucked in from over tightening. If you gear selectors are worn out I might have a set.
Kirk
2017 Ford Expedition SUV (A59231)
2017 Ford...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2006 Ford F-150 Pickup Truck (A59230)
2006 Ford F-150...
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
2016 Isuzu NPR 16ft. Box Truck (A59230)
2016 Isuzu NPR...
2010 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2010 Dodge Ram...
