96 Pantry and 8 Ceiling
   / 96 Pantry and 8 Ceiling #1
dieselscout80
South Carolina
New Holland TC45DA
How to install a 96 Pantry in a kitchen with 8 Ceiling?
The base/toe kick is separate.
My thought is trim a hidden side of the cabinet side flange.
Then set and level the base.
The use a hand truck to raise the cabinet and then slide it on the base.
Does that sound like a plan?
   / 96 Pantry and 8 Ceiling #2
Are you going to put trim or crown up after? That's what I did on my pantry cabinet and oven cabinet. Also, my floors and ceiling were not perfectly level, I ended up finding one spot in the room that gave me an extra inch to tilt them up so I had to trim less. Swung the tap measure from the bottom front corner and trimmed the back.
Sorry about poor lighting but you get the idea.
I wouldn't bother with the hand truck, just more chances to "ding" the cabinet. I would "walk" it over, tilt one side onto the base and push it in.
   / 96 Pantry and 8 Ceiling #3
Most toe kicks are 3 1/2 inches tall. How deep is the pantry? My guess is that you won't have enough room to tilt it up. Before trying to get it into place, I would see how high the back of it goes when tilting it up.
Can you cut the thing in half? Then put some trim over the cut, or bevel, bondo, sand and paint the cut?
No cutting can happen as they are pre-finished cabinets.
Cabinet is 91 and 9/16” tall, the base is 5 and 5/16” then the base sets up inside the bottom of the cabinet by 15/16”.
   / 96 Pantry and 8 Ceiling #5
That's a tall base. I've rounded off the top back corner of cabinets to get them to fit before. Sometimes all you need is that little bit to get it to work
   / 96 Pantry and 8 Ceiling #6
I have to ask how you got in this predicament? :D
   / 96 Pantry and 8 Ceiling #7
How good is your plaster work? Chop a tilting hole in the ceiling between 2 joists, then patch?
   / 96 Pantry and 8 Ceiling #8
If you can't find an easier solution...cut enough off the top to get it in place and use some molding (crown etc...) to trim it out...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
UNUSED Wheeled Dump Hopper (A47477)
UNUSED Wheeled...
2011 WESTERN STAR  4900 SB (A55745)
2011 WESTERN STAR...
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
John Deere 5603 (A53314)
John Deere 5603...
