?95 mazda B2500 truck stalled, won't restart
   / ?95 mazda B2500 truck stalled, won't restart #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
cousin was driving, 1/4 tank fuel, went around a corner, truck stalled, she pulled over.
i went out to look at it.
battery turns over starter fine. lamps and gauges work, I checked for fuse burnouts, found none on the panel just inside the door.
I pulled a spark plug wire and held it near ground and it has spark. I had to get back to work so I just towed her here.
I'm ?wondering? about fuel pump.
at key-on, I don't here any fuel pump charging up the plenum... but wasn't sure on this truck how that worked.
Ps.. this truck has lots of stuff that crosses with a ranger. ;)
Also.. thru me off when i counted spark plug wires at first. ;)
If this does have a pump that should be running.. is this a rail /frame mounte dpump or in the tank? and is there a charge pump under the hood?
thanks
more info... it is a 5/98 now that I look at the door panel.
Also.. I found the timing has jumped, and finally now the belt broke.
how do you re - time these engines.
2.5l engine by the way. ;)
Figured it out, timing belt tore, it jumped time. Got new belt coming, have it about half torn down, found my 3 marks. If rain will hop up, might finish on thursday
2001 Dodge Ram Wagon 3500 Passenger Van (A51692)
2001 Dodge Ram...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
2013 New Holland T4.75 Tractor (A52384)
2013 New Holland...
2021 John Deere 310SL Backhoe (A53342)
2021 John Deere...
