Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 51,575
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
cousin was driving, 1/4 tank fuel, went around a corner, truck stalled, she pulled over.
i went out to look at it.
battery turns over starter fine. lamps and gauges work, I checked for fuse burnouts, found none on the panel just inside the door.
I pulled a spark plug wire and held it near ground and it has spark. I had to get back to work so I just towed her here.
I'm ?wondering? about fuel pump.
at key-on, I don't here any fuel pump charging up the plenum... but wasn't sure on this truck how that worked.
Ps.. this truck has lots of stuff that crosses with a ranger.
Also.. thru me off when i counted spark plug wires at first.
If this does have a pump that should be running.. is this a rail /frame mounte dpump or in the tank? and is there a charge pump under the hood?
thanks
thanks
