94 Ford F250 battery cable
/ 94 Ford F250 battery cable #1
Alan L.
Elite Member
Grayson County, TX
Kubota B2710
The terminal for the positive side of one of the batteries (diesel) is loose and wallowed out and you can't get it tight. I would get a new terminal and clamp it on there, but the problem is that the terminal is not at the end of the cable. Instead, the cable keeps going past the battery.
Anyone know of a way to fix this without replacing the entire cable? The replacement cable is $100 but more importantly it appears it would be very difficult to replace - its long and goes down in the engine compartment to the starter, etc where you can't see it.
/ 94 Ford F250 battery cable #3
/ 94 Ford F250 battery cable #4
My local VIP Auto and NAPA Auto parts stores have the crimp tools they rent for free ($50 deposit returned when tool is returned). I also found a good vise, hammer and chisel work really well in a pinch too! :D
/ 94 Ford F250 battery cable #5
My grandfather used a penny for that one time, basically just a shim.
/ 94 Ford F250 battery cable #6
The copper penny/washer will probably work. Put the penny on top of a vise opened to about 1/2 in, and lay the penny/washer on top, and lay a rod across the penny/washer and smack it to round it. Then insert it in the clamp and tighten down. I have an F-250 diesel, and if the battery cable came loose, that is what I would do.
Could use one of these and connect both cable ends to the terminad stud.
http://www.usahardware.com/inet/shop/item/03110/icn/20-343426/east_penn/00354.htm
http://www.youtube.com/watch?v=9sUBo10H96Y&feature=email
http://www.youtube.com/watch?v=SXDkNMDDrBs&feature=email
/ 94 Ford F250 battery cable #7
Aha! I knew there was more to it than I was seeing. I'm not too crazy about the hammer and chisel method, but renting a crimper sounds like a plan.:)
/ 94 Ford F250 battery cable #8
I made many good cables using welding lugs from TSC, welding cable. solder and plumber's torch. You melt the solder inside the lug hole and when it is a nice puddle, just insert the end of the cable (with insulation cut off). It lasts forever, there is no space for any oxydation and it looks good. I usually cover it where possible with shrinkable tubing to minimize the exposed metal.
If I am reading your problem correct then just the connector is coming loose, if that is the problem then just get a new "Flag" connector and replace it. That cable is 2/0 AWG so here is the connector I would use: Battery Flag Connector Terminal | 2/0 Gauge 4320N Negative Flag Clamp - Remy Battery
That looks EXACTLY like what I need! There is talk of crimping with a tool or using a vice - any chance I am going to be able to connect this on the truck without pulling the entire harness off the truck? Also, I wonder if the cable could be soldered to the connector?
Looks like I would need to cut the existing terminal off the cable with bolt cutters and be sure to leave enough wire to work with.
/ 94 Ford F250 battery cable #10
If the cable is long enough after cutting out the bad section, and you have the correct cable crimper, then you should be able to do it while still in the truck.
/ 94 Ford F250 battery cable #11
I agree with J_J, except to say that sometimes cable connections may have lots of corrosion as far as 1-1/2" up inside the insulation. I think you are going to have to find a way to clean off the corrosion and neutralize the acid before crimping on a new connector. The perfect crimp connection will be so tight that it will be liquid and even vapor proof. It's not likely you will be able to reproduce such a good connection by doing it on the truck, but it may be good enough to last a very long time if you get it clean enough. Preparation of the wire before crimping will easily be 80% to 90% of the job. Starting a diesel pulls so much current from your batteries that you need every little strand of wire to do its job or the connection will overheat and bad things will happen.
/ 94 Ford F250 battery cable #12
You could soak the end in a cup of Coke Cola for 5 or 10 minutes then wipe with oil. Has always worked for me on battery post/connections. I pour a Coke on it, dry it off and oil.
I never get corrosion.
/ 94 Ford F250 battery cable #13
If you can't get insulation all around the metal, a nice gob of dielectric grease will keep it from corroding....of course you then have a nice gob of grease to collect junk.
Chuck
/ 94 Ford F250 battery cable #14
You shouldn't have a problem getting that connector on without removing the cable. Removing the cable is not easy, I replaced that cable on my 94 F-350 diesel when I replaced the starter.
If you cannot get the crimp tool from your local parts store as a rental then try using a C-clamp. I have been able to start crimping a connector with a large C-clamp and finish it off with a hammer. ;)
/ 94 Ford F250 battery cable #15
Solder it in....That's what I do to all of my battery/wire connectors. Crimping encourages corrosion pockets. Besure to clean off all flux paste. Fill that void up with solder.
/ 94 Ford F250 battery cable #16
Exactly my point - great minds think alike:)
/ 94 Ford F250 battery cable #17
If you solder, do not use plumbing acid flux. Electrical soldering should use rosin flux only. You can clean off the rosin flux with isopropyl alcohol (rubbing alcohol).
/ 94 Ford F250 battery cable #18
I usually use the electrical solder that has the flux already with it. And as Czech says use shrink tubing. That's what I do also. Then cover with either another layer of shrink, and or back over the joint with electrical tape. Ready for Indy, or the moon shot. hehehe:D;)
/ 94 Ford F250 battery cable #19
Instead of standard electrical tape I might use the new epoxy tape that bonds to itself and makes a nice seal. I've used it only for plumbing so far, but it says on the packaging that it is also good for electrical insulation, and unlike standard electrical tape, when it is applied properly it shouldn't come unwound.
Chuck
Are we talking solder by using a torch, or a soldering iron? I have sweated pipes and I have soldered small wires with a soldering iron, but haven't done electrical with a torch. I suppose I will need a plumber's torch and rosin core solder?
Get a bunch of solder melted in there then shove the wire in? Or put the wire in and solder what you can see?
How can I be sure my truck is a 2/0 wire for when I purchase the flag connector?
Seems like I am going to have to be very careful how I cut the wire or it will end up too short. I wonder if the wire is continous all the way through the existing connector, or if it is two wires coming into it? I was wondering if I could heat it up and pull the wires out.
I use a crimp tool should I be able to get enough leverage on the tool to crimp it with the connector in the truck?
2013 WACKER NEUSON LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
Unused 2021 Berti 112in. Handy 230-280 Hydraulic Flair Mower Tractor Attachment (A66734)
Unused 2021 Berti...
2013 FREIGHTLINER CORONADO 122 SD (A67714)
2013 FREIGHTLINER...
2018 GRASSHOPPER 900D MOWER (A66091)
2018 GRASSHOPPER...
2008 Ford E-250 Cargo Van (A66736)
2008 Ford E-250...
GAYLEAN  130BBL VACUUM TRAILER (A67714)
GAYLEAN 130BBL...
