93 ford 3930
/ 93 ford 3930 #1
jawz41
How much flow (gpm) from hydraulic pump to operate implements.
/ 93 ford 3930 #2
The flow is different for different implements. You will be limited to the GPM's that your tractor produces, unless you add a PTO pump. but you still need to figure the HP. The hyd motor on the implement would be designed, taking into account, width, speed, mass/weight needed to turn and maintain a constant force, etc. The more HP and more GPM's, the larger implement you can pull and operate.
/ 93 ford 3930
My question is what is the flow from the tractors hydralic pump. With tractor turning 1800 rpm's how many gpm for a log splitter with a 4 x 24 cylinder. I like to run it around 1200-1400 rpm's what would be the gpm? I think the tractor is rated @ 45 pto HP. From what I read you need 11 gpm for a 4 x 24 cylinder.
/ 93 ford 3930 #4
Only you would know the pump output. The pressure will be what the relief valve is set at. The rpms dictate the GPM available. A log splitter will run with any pressure up to the pressure limit of the components, and any GPM. Higher pressure, more force. More GPM's faster operation.
/ 93 ford 3930 #5
According to TractorData, your 3930 has a flow of 8 GPM. That rating is usually at the 540 RPM PTO speed indicated on your tachometer.
/ 93 ford 3930 #6
8 GPM for tractors with a single pump. If fitted with the auxiliary engine mounted pump (left rear of the engine block with spin on filter oriented horozontally inline with chassis), a combined flow of about 16GPM is available at the remote couplers.
/ 93 ford 3930
Thanks, Rick B. :thumbsup: Good point, I need to get a manual.
/ 93 ford 3930 #9
2019 BOBCAT E45 EXCAVATOR (A63276)
2019 BOBCAT E45...
2024 John Deere 561M Heavy Duty Round Baler (A63111)
2024 John Deere...
2025 SAWYER 85BP20 20FT T/A ENCLOSED BUMPER PULL TRAILER (A59912)
2025 SAWYER 85BP20...
RoGator and Terragator Manuals (A63117)
RoGator and...
2018 PJ Trailers 14ft T/A End Dump Trailer (A61573)
2018 PJ Trailers...
2025 Swict 72in Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
