9220 transmission overfilling
/ 9220 transmission overfilling #1
jd1985man
Binger, Oklahoma
John Deere 9220 2007model
I have a 9220 JD my transmission oil level rise to overfull about every 50 hours. I just recently had the clutch replaced and all new O-rings put in the hydraulic pump. Jd dealer thought this would fix the problem. Just wondering if anyone else has had this problem and if oil could be getting in from somewhere else like the steering cylinders?
/ 9220 transmission overfilling #2
You would think if it is rising in the transmission that it would have to show up as falling somewhere else.
If you have cavitation in the system air entrainment may be the culprit as the air bubbles would seem to make the level read higher. I would check this next time it is reading over filled by shutting down for 30 minutes and then recheck. That would give the air bubbles time to surface.
2011 JAYCO TRAVEL TRAILER (A67714)
2011 JAYCO TRAVEL...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64194)
2017 Caterpillar...
2012 CAT D60-6 GENERATOR (A67714)
2012 CAT D60-6...
20' CONNEX BOX (A67714)
20' CONNEX BOX...
KL480 Ventrac tiller
