9 Uses for Toothpaste Other than Brushing Your Teeth
   / 9 Uses for Toothpaste Other than Brushing Your Teeth #2
There was quite a few there. I'm sure everyone has heard of the filling holes in walls one, and I have tried it, just make sure the house isn't yours.
When I was a kid I had a new watch with a glass face, and I cleaned it with a harsh chemical when it was dirty which caused it to haze the glass so much you couldn't read it. My dad felt bad, and the next day picked it up just looking at it and rubbed it with his thumb. He aparently still had a bit of toothpaste on it from brushing, and it made a clean spot. He then took it upstairs and cleaned it with toothpaste, and it looked good as new, so I definately believe the shower door thing. Go figure.
   / 9 Uses for Toothpaste Other than Brushing Your Teeth #3
It also can be used to remove scratches from sunglasses.
   / 9 Uses for Toothpaste Other than Brushing Your Teeth #4
Sunblock for the nose and ears!
   / 9 Uses for Toothpaste Other than Brushing Your Teeth #5
Coworker that was aircraft AP mechanic used toothpaste to remove scratches from aircraft windshields. MikeD74T
   / 9 Uses for Toothpaste Other than Brushing Your Teeth #6
And I heard to buff into those plastic "faded" headlight s.(although i havent tested it yet) on my llst..
   / 9 Uses for Toothpaste Other than Brushing Your Teeth #8
I knew the polishing, it is fine abbrasive paste.
   / 9 Uses for Toothpaste Other than Brushing Your Teeth #9
From my old US Navy days, 1) a fine polish for brass (belt buckles), 2) polish watch crystals after using Brasso for the rough grinding, 3) Clean dirty spots off of white hats (I learned this in bootcamp.)
   / 9 Uses for Toothpaste Other than Brushing Your Teeth #10
Used it to polish my boats while in the army.
2018 Ford F-250 Reading Enclosed Service Truck (A55788)
2018 Ford F-250...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
