9 Uses for Toothpaste Other than Brushing Your Teeth
   / 9 Uses for Toothpaste Other than Brushing Your Teeth #2
There was quite a few there. I'm sure everyone has heard of the filling holes in walls one, and I have tried it, just make sure the house isn't yours.
When I was a kid I had a new watch with a glass face, and I cleaned it with a harsh chemical when it was dirty which caused it to haze the glass so much you couldn't read it. My dad felt bad, and the next day picked it up just looking at it and rubbed it with his thumb. He aparently still had a bit of toothpaste on it from brushing, and it made a clean spot. He then took it upstairs and cleaned it with toothpaste, and it looked good as new, so I definately believe the shower door thing. Go figure.
   / 9 Uses for Toothpaste Other than Brushing Your Teeth #3
It also can be used to remove scratches from sunglasses.
   / 9 Uses for Toothpaste Other than Brushing Your Teeth #4
Sunblock for the nose and ears!
   / 9 Uses for Toothpaste Other than Brushing Your Teeth #5
Coworker that was aircraft AP mechanic used toothpaste to remove scratches from aircraft windshields. MikeD74T
   / 9 Uses for Toothpaste Other than Brushing Your Teeth #6
And I heard to buff into those plastic "faded" headlight s.(although i havent tested it yet) on my llst..
   / 9 Uses for Toothpaste Other than Brushing Your Teeth #8
I knew the polishing, it is fine abbrasive paste.
   / 9 Uses for Toothpaste Other than Brushing Your Teeth #9
From my old US Navy days, 1) a fine polish for brass (belt buckles), 2) polish watch crystals after using Brasso for the rough grinding, 3) Clean dirty spots off of white hats (I learned this in bootcamp.)
   / 9 Uses for Toothpaste Other than Brushing Your Teeth #10
Used it to polish my boats while in the army.
BUNDLE OF 40" X 64" EXPANDED METAL (A54756)
BUNDLE OF 40" X...
2016 Toyota Prius Hatchback (A53424)
2016 Toyota Prius...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
Kubota SVL95-2 High Flow Cab Skid Steer (A55302)
Kubota SVL95-2...
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
2007 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XL...
