8n throttle rod
   / 8n throttle rod #1
rjhans53
Mulberry, FL
Iseki 1910 Ford 8n B
I really don't think it should be this big of a pain. I changed out the steering box and when I went to put it all back together there is now clear path for the throttle rod. It came out really hard but I just figured it was rust and crud. I've got it back in (and because it was such a pain figured out I'm missing the spring on the bottom) but I've got 3 bends in the rod and it seems to work ok. The ball in the throttle arm is flat and I'll figure that out but is there suppose to be a clear path for the rod or is this typical
   / 8n throttle rod #2
clear path for the rod.
if the ballis flat use a flat blade screwdriver to spread the metal, roll the ball over and then peend the sides a bit.
   / 8n throttle rod
Wow I'm missing something big time. I can't even get a 1/4" rod down straight, It runs into a threaded sleeve. Yep the ball is flat and the bottom spring isn't there. I have a spring ordered
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2019 Dodge Journey Crossroad SUV (A53424)
2019 Dodge Journey...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
