8n throttle rod
   / 8n throttle rod #1
rjhans53
Bronze Member
Mulberry, FL
Iseki 1910 Ford 8n B
I really don't think it should be this big of a pain. I changed out the steering box and when I went to put it all back together there is now clear path for the throttle rod. It came out really hard but I just figured it was rust and crud. I've got it back in (and because it was such a pain figured out I'm missing the spring on the bottom) but I've got 3 bends in the rod and it seems to work ok. The ball in the throttle arm is flat and I'll figure that out but is there suppose to be a clear path for the rod or is this typical
   / 8n throttle rod #2
clear path for the rod.
if the ballis flat use a flat blade screwdriver to spread the metal, roll the ball over and then peend the sides a bit.
   / 8n throttle rod
Wow I'm missing something big time. I can't even get a 1/4" rod down straight, It runs into a threaded sleeve. Yep the ball is flat and the bottom spring isn't there. I have a spring ordered
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
2017 TRAILSTART 40FT DUMP TRAILER (A54607)
2017 TRAILSTART...
2012 Honda Accord Sedan (A53424)
2012 Honda Accord...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
