8N power steering
/ 8N power steering #1
azgoldust
Dolan Springs, AZ
ford 8n
Adding power steering and an FEL to my old friend and have a couple of questions.
1. in normal hydraulic runs, using 3/8 hose, what size rigid tubing is required?.
2. does the 3 point lift hydraulics flow enough for power steering, I will be using
a pair of 1.5 bore cylinders on the drag links with a dedicated valve and lost motion device
to actuate the valve
I have also mounted a 3 GPM pump driven off the crankshaft which I plan to use
for the FEL or should I reverse the two sources.
The pic is a mockup of the pwr steering before I clean every thing up
for the finish.
500 BBL WHEELED FRAC TANK (A67714)
500 BBL WHEELED...
DRAGON 500BBL WHEELED FRAC TANK (A67714)
DRAGON 500BBL...
2018 JOHN DEERE 320G SKID STEER (A65056)
2018 JOHN DEERE...
PORTA POTTY (A68842)
2008 Audi A4 AWD Sedan (A66738)
2008 Audi A4 AWD...
