8N power steering
/ 8N power steering #1
azgoldust
Dolan Springs, AZ
ford 8n
Adding power steering and an FEL to my old friend and have a couple of questions.
1. in normal hydraulic runs, using 3/8 hose, what size rigid tubing is required?.
2. does the 3 point lift hydraulics flow enough for power steering, I will be using
a pair of 1.5 bore cylinders on the drag links with a dedicated valve and lost motion device
to actuate the valve
I have also mounted a 3 GPM pump driven off the crankshaft which I plan to use
for the FEL or should I reverse the two sources.
The pic is a mockup of the pwr steering before I clean every thing up
for the finish.
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2025 Kivel Quick Hitch Skid Steer Attachment (A59228)
2025 Kivel Quick...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
STEPP SEALCOATING MACHINE (A59906)
STEPP SEALCOATING...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
iDrive TDS-2010H...
