8n lift control
/ 8n lift control #1
Rockwell
51 Ford 8n
is it normal for all control of lift arms to be in the top 1” of the quadrant?
I am having awful time trying to level some sand with control being difficult.
thank you
/ 8n lift control #2
thank you
That is certainly not the way the lift arms work on my '51 8N
/ 8n lift control #3
Make sure the little lever under the seat is in the implement control position (horizontal) and not in draft position (vertical), if it is in the correct position then the cam follower pin is worn out and possibly the cam is worn as well. To fix that you must remove the top cover and replace the pin, I usually replace them with piece of 5/16 drill bit. If the cam is worn it can be built up with a torch and some bronze rods.
/ 8n lift control
Thanks so much for reply’s.
did replace the follower pin, cylinder, piston and o ring etc. but I do in fact have lever in draft position 😳.
will try that tomorrow for sure. My blade drifts down to ground in about 5 minutes. No dripping from above but there is foam riding out of my pump when blade drifts dn.
/ 8n lift control
Well I put the lever in implement control position but it burst my excitement by still only controlling with top inch of quadrant.
When control lever is moved slowly to within inch of quadrant top the back blade starts to lift and shudder and moves to total up position without further movement of control lever.
/ 8n lift control #6
Sounds like it is time for an R&R of the top cover linkages.
/ 8n lift control #7
I would agree.
Had a similar issue with my Ford 1920 (1989), and it required a new lift piston seal.
Not a bad job, and works fine now.
/ 8n lift control
Thank you for the kind replies.
I have installed new cylinder with new style piston. No leaking from top side now but foaming from inside of pump as back blade drops.
have installed new cam follower pin and adjusted linkage with Zanes thang.
/ 8n lift control #9
Did you by chance replace the relief valve? With the side cover off look for swirling oil at the back of the pump. With a new pin and adjustment with Zane's tool it should be right.
/ 8n lift control
Thank you much for that tip!
I did at one point and didn’t see any noticeable oil swirling but will look for that again.
Is a problem in the pump a possible cause of my control issues?
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
VOLVO L90E WHEEL LOADER (A64279)
VOLVO L90E WHEEL...
35" EXCAVATOR BUCKET (A64280)
35" EXCAVATOR...
72in Bucket Skid Steer Attachment (A61572)
72in Bucket Skid...
2011 CHEVROLET TAHOE (A63276)
2011 CHEVROLET...
10 ft bed. 14 ft trailer (A61567)
10 ft bed. 14 ft...
