8n charging
/ 8n charging #1
Marks8n
Ford 8n
Hello. I have a 48 ford 8n that I bought in the summer. I am going to use it mostly for snow removal. It has a 8V battery and the regulator has 9.2V written on the cover. I was told the genny was tweaked as well. I assume the brushes were adjusted. If its that type. Problem is it won't charge. Starts and runs fine but only shows 8.2v running and slowly goes down. Any tests for the volt regulator and the genny? I'm new to tractors and 6V / 8V positive ground. Thanks.
/ 8n charging #2
Mark,
Have you polarized the generator? If not I would re-polarize the generator first then check the voltage directly on the generator, if it is higher your regulator is either bad, needs to be adjusted, or you have a bad connection. If it is not higher I suspect the generator is the culprit of your problem.
I am not sure how much voltage the oem generator will crank out but I would think it should charge a 8v batt ok.
Philip.
/ 8n charging
Thanks Philip. How do do I polarize the generator?
/ 8n charging #4
Mark,
Take a scrap wire and put it on the generator armature post to the battery MOMENTARY! Don't hold it on there, just spark it. Hopefully this is your problem.
Check this out:
Polarizing Your Generator
/ 8n charging
Do I go to the battery negative or positive ? It is positive ground on my tractor.
LOT OF METAL GATES (A63291)
LOT OF METAL GATES...
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
2014 Chevrolet Express Shuttle Bus (A61573)
2014 Chevrolet...
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
2016 Kubota L3301 (A62177)
2016 Kubota L3301...
VICON ROTOFLOW SPREADER (A63291)
VICON ROTOFLOW...
