8n/9n Guys
/ 8n/9n Guys #21
You may have to search for it but a ford 2000 (1960's) or a 3cyl dexta perkins deisel can be found for $2500.00.rock solid 3 speed hi 3speed creeper trans with about 33 hp.this is my Fix Or Repair Dailey 9n replacement.It will handle all you are asking for and 6foot kk bush hog. also look for a massey fergision with a perkins 3cyl deisel.
/ 8n/9n Guys #22
Be carefull... that 3 cyl you refer to is a 3cyl, post 65 unit.. not a 62-64 4 cyl.. which has close to 33hp.. that 3 cyl has a few more ponies.. I'd guess more like 36 at the engine.. 32pto, and 28 drawbar.. etc..
soundguy
/ 8n/9n Guys #23
If you could find a 3 cyl deisel 2000 in good condition for $2500 then you would have quite a find. I sold one that was well worn with over 8000 hours 3 years ago for $4500. It was a good tractor and didn't owe me nothing as that was a little more than I paid for it 10 years previous. The $1500 limit is well under half what it would take to get into one of these. This is the size tractor that has the highest demand. You probably could find an old 5000 or larger for under $2500 with far less effort, especially a gasser.
/ 8n/9n Guys #24
I agree.. finding a 3cyl 2000 gas or diesel for 2500$, will be VERY difficult.. and if you do.. it is likely used up... I saw a 2000 diesel 3cyl that had bowed radius rods.. loose kingpin and bad front end bushing.. leaky but working hyds.. bad brakes, and virtually non existant power steering, and was addicted to ether.. owner asked 4000 and had no problem selling for 3500 in a couple days..
soundguy
/ 8n/9n Guys
sorry, i haven't been able to log on for a while. Thanks for all the replies. I think i'm going to stay away from the 8/9n due to the fact that i really need a loader. I think i'm going to have to buck up and spend a few more dollars to get something that is close to what i want. is a ford 600 basically just a little newer model than the 8n's? they really don't look much bigger. I also found an IH 244 on craigslist. I know this isn't the correct spot to ask about it but does anyone know anything about these tractors?
/ 8n/9n Guys #26
The 600 (or jubilee) is a better choice for a loader than the n's. It is, like the n's, still a 2-plow tractor and will not offer much more for drawbar pull. The live hydraulics and bulkier size do help with a loader, and the additional pto hp helps out a lot on a brush hog. Like the n's however, they lack power steering and 4wd, rendering them less than ideal for a loader but certainly adequate for lighter jobs like manure handling. You can probably find a decent 600 for almost the same price as you could find a later model 8n. Of the 2 models, the 8n is certainly my favorite because of its better historical significance, power/weight ratio, parts support, fuel economy, and hydraulic durability (these are the reasons the late 8n's fetch the same price as 600's these days). If brushhogging and loader work were my primary tasks however, I would certainly go with the 600 / jubilee. In most areas where I have been, a decent 9n/2n can be found for around $1500, while a 51/52 8n (with side distributer and proofmeter), or jubilee/600 will cost you around $2500. I never looked at any of them with loaders, but the jubilee/600 with one would probably cost you an extra $1000 or so, while you probably wouldnt have to pay much if any more for an n with a loader because they are so poorly suited for this attachment.
/ 8n/9n Guys
thanks wolc123!
i'm still trying to find the best deal i can. i keep thinking that bigger is better. the tractor that i buy now is going to be around for a while so i want to make sure it is going to be able to handle my abuse.
/ 8n/9n Guys #28
You *can* find 600's with power steering.. it was a factory option.. preferably, get a 660.. it will have live pto. For still near the same money, you can get an 800/801 unit.. again.. preferably an 86*.. it will have twice the hp of an N, live pto, optional power steering, and a heavier rear end.
The hundred series have more volume hyds than the NAA/jubilee. Naa had 2.85gpm same as the N's... the 600/800 had 4gpm hyds..e tc.
( you can get a front pump driven off the crank.. or for the live pto models.. you could go with a pto pump and a pto shaft extender.. though that would not be my first choice. )
I run loaders on my 3 hundred series tractors.. a 660, an 850, and a 951.. I use the onboard 4gpm hyd pump, and my loaders lift 1000-1200# and will breakout 2500-3000# .. good medium duty loaders for homeowner needs... I would not use them comercially... No power steering on any of them.. though a concrete counterweight helps on my dedicated loader units..
soundguy
/ 8n/9n Guys
soundguy,
do your loaders have a hydraulic down? it seems like a lot of older ones are a "free fall" style. i don't think that would be good for what i want. is there an easy way to add another cyllinder or something to be able to have hydraulic power to push the bucket down
/ 8n/9n Guys #30
My loaders are gravity down.. however the hyd spool valves on 2 of them have support for a da cyl vs a SA cyl on the lift circuit.. thus i could swap the OEM SA lift cyl for a DA cyl, and then have power up/down. It already had power cump/curl.. etc.
soundguy
2013 Ram 5500 Bucket Truck, VIN # 3C7WRNALXDG552597 (A61165)
2013 Ram 5500...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2020 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2020 Kubota...
2017 Autocar Xpeditor T/A EZ-Pack 40Yd Front Loader Garbage Truck (A59230)
2017 Autocar...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
