Buying Advice 86 John Deere 850
/ 86 John Deere 850 #1
kptractor6
Yucaipa, CA
none.....YET.....
Hello, I am looking for some advice. There's a JD850, which is 4wd but it doesn't have a drive axle on the front so it is currently 2wd. What is the ballpark to put a drive axle on the front and would parts be an issue? The tires are in need of replacing, it has a 20" rear wheel rim, the only ag tire I can find priced close to $600. Are there any alternatives? Will a military tire fit? The guy is asking 5000 for the tractor, he said he'd take 4500 but it really needs tires and a rear box scraper which will add another 1200 for me to put on, unless I can find a good deal on tires. I think if I can get it for 4000 it would be a good deal. Thanks for your help on this.
/ 86 John Deere 850 #2
I know from talking to Washington Tractor in Snohomish Wa that parts are lacking for the front final drives, so I would guess that the entire assembly is even more rare. That is probably why it's now a 2WD. I think you're going to be really hard pressed to turn it back to 4WD.
/ 86 John Deere 850 #3
Personally, I'd pass on this one. As Rock knocker wrote, finding the components might be a challenge. I doubt you'd get any help from any Deere dealer. Parts from a salvage yard might be something to consider.
But, considering it needs new tires as well...I just don't see this being a good deal.
/ 86 John Deere 850 #4
If missing front drive parts, Id price it as a 2WD. You also did not note the hours. 20" tires sounds odd to me. I thought 16" and 24" were the standard back then. The other thing Id add, although the JD 50 series were reliable tractors, they only had 2 reverse gears, slow and 'waiting for payment' slow. That would drive me nuts.
/ 86 John Deere 850 #5
Hiya,
Shipping may be an issue but there is a guy on CL in NH that has two 4x4 Deere 850's he's parting out. IIRC, these were practice tractors at a tech school and they were 'Fixed" to death. I don't know if posting CL links is a no-no here but if you want to PM me I'll get it to you.
Tom
/ 86 John Deere 850
Thank you for all of the responses. I think that it confirms to me that this isn't the right deal. I am very appreciative of the time you guys took to respond.
/ 86 John Deere 850
I have also seen a JD 950, 85, 1200 hours, 2wd. It has a box scraper with rippers, fel, no ROP, and the tires look to be in good shape. As far as parts go, am I in the same situation as the 850?
/ 86 John Deere 850 #8
The parts for the 50 series can be found if you look enough. It is the 4WD parts that are a bear to find. The 950 is also an excellent tractor. Just be aware of a 2WD loader's limits.
2014 JAYCO JAYFEATHER TRAVEL TRAILER (A63569)
2014 JAYCO...
2021 Kubota SVL75-2 Track Loader (A63118)
2021 Kubota...
2024 Blue Diamond Skid Steer Vibratory Roller (A63116)
2024 Blue Diamond...
2007 MACK CXP613 (INOPERABLE) (A63569)
2007 MACK CXP613...
2024 Bobcat T740 Track Loader (A63109)
2024 Bobcat T740...
2021 John Deere 333G Skid Steer (A63109)
2021 John Deere...
