855 attachments
/ 855 attachments #1
99S10
Pittsburgh
94 John Deere 855
If all goes well I will be bringing home an 855 tomorrow with a FEL and the Ag tires. Couple questions. I have a Woods RM306 I want to use. It's the old style with the check chains and big pulley in the middle..no gearbox. Any issues using it? Also, I want to get a 3pt tiller. What size should I get 4 or 5 ft? Thanks.
/ 855 attachments #2
What speed is the mower intended to run at? I have an old Woods brush mower intended to run at about 1000 RPM PTO speed which means it doesn't exactly work for my 855. I think were I buying a tiller, I'd go for 4 ft. Not too narrow and not as likely to over power your tractor.
/ 855 attachments #3
99
Being hydro tranny, I think I'd go 5' on the tiller. Can go slow, and at a depth that the 855 and 19 PTO hp will handle. Nice when you can cover the wheel tracks. If it were gear, then I'd suggest 4' too.
That mower is a finishing mower, so see no issues with connecting to your 855. As long as the rpm of the PTO is correct.
/ 855 attachments
Yeah the rpm is 540 so should be OK. It does a nice job behind my old Ferguson. I keep it set up as high as it will go and just use it in my open field...about 3 acres. I used to have trouble with gangs of kids roaming through but not so much since I raised the deck height. lol
Guy on another site said he has used a 6ft tiller behind his 755 going slow. So I'm thinking a 5 ft would work OK. Thanks again. Can't wait to get it.
/ 855 attachments #5
i have a JD 750 gear, same general size (just a bit smaller) i use an old woods rm59 and look it. i also have a 52" woods tiller and it does fine behind the 750. i could run a 5ft tiller but i don't have one.
/ 855 attachments #6
855 hydro......everything 5' or 6'. Depends on weight of attachment. Most dealers and pundents say 4' to 5' max.....they never owned one or never used one. Had a backhoe attachment that I would dig footers and crawl spaces with. Used a 7' York rake. Had 6' belly mower thus a 6' bush hog would work as long as one was cutting grass and light stuff. Had a 5' two stage snow blower ...worked great. Hydro helps greatly. great tractor......Farmall H was only 19 horsepower....weighted bunches more but it wasn't 4 wheel drive either.
/ 855 attachments #7
5 foot will cover your tracks and it will pull it fine. Some 4 foot models are offset to one side, you just have to work the same direction from one side of the garden to the other. I pull a 5 with my 2520 and it pulls it fine, I'd rate it at about the same power that my 855 had.
/ 855 attachments
I just noticed a 6' belly mower for sale locally. It looks like the ones I've seen on 855/955 but the ad says it was on an 870. Is there any way to determine fitment on these?
/ 855 attachments #9
I believe I saw a footnote somewhere that said the 72" MMM deck was not compatible with 11.2-16 R1 rear tires on the 855.
/ 855 attachments #10
I'm not 100% sure, but think the deck is the same... just different tractor mounting hardware for 870.
/ 855 attachments
I have all the mounting stuff from the 60" basket case I got with the tractor. It's so close I should go look with a tape measure.
/ 855 attachments #12
I think they only made one 60" deck for the larger tractors. As stated I think they just changed the mounting hardware, so you should be good to go.
/ 855 attachments
I checked the parts catalog and the deck shell has the same part # So the mower itself should fit. But I would be concerned about the PTO shaft as the 870 is a gear tractor. The catalog shows a lot of different numbers for the shafts. PTO speeds are the same though. I guess I'll just have to go take a look since it's only 15 minutes from me.
I saw another 72" deck for sale on Craigs that is off an 855. The tractor is in the photo and it has R1 tires on it.
/ 855 attachments #14
May just be the shaft length. Ran into that trouble with a friend of mine, he bought a different deck for his tractor. Had to change the half of the shaft closest to the tractor. I think they just sell a universal length one now and they cut it to length.
/ 855 attachments
Went and looked at it. The frt arms are the same but the rear lift straps are different. They go to the rear back by the 3 pnt hitch. The ones I have for the 60" are different also. New ones are 300 bucks so forget that idea. It didn't look used a lot but has been laying outside. If it stays there much longer it will be junk.
2018 FREIGHTLINER CASCADIA 125 6X4 T/S SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
GAS CYLINDER TRANSPORT BED (A67714)
GAS CYLINDER...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2000 PETERBILT 378(INOPERABLE) (A67714)
2000 PETERBILT...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
2011 PREMIER PUMP AND POWER 3IN 3HC-DM16 TOWABLE PUMP (A67714)
2011 PREMIER PUMP...
