8540 clutch adjustment?
/ 8540 clutch adjustment? #1
millstreaminn
Northern Pa
Kubota 8540, 4800, L39, 7510, Zd28 International 966, Cat 304, Mahindra 4035, Deere 350 and 450, Komatsu D21
I've got a Kubota 8540 cab, 8 forward, 8 reverse with 220 hours on it. I bought it used across the country and it is out of warranty. What I would like to know is there any way to adjust the clutch on it? It seems to be an "all or nothing" type of setup. I have thousands of hours on tractors both bigger and smaller than this one. I have never driven anything with as sensitive a clutch as this.
Thanks for the info!
Is there no way to adjust the clutch or doesn't anybody know/care???
/ 8540 clutch adjustment? #3
It seems to be the nature of the beast. Is yours hydraulic or syncro shuttle?
Thanks DT86. It's a syncro shuttle.
/ 8540 clutch adjustment? #5
Sorry, I don't know, ours is a hydraulic clutch.
Thanks- TripleR. My 3940 and L39 both have the GST tranny on them which basically lets you shift between forward and reverse and all gears without clutching. Even when I use the clutch on them, you don't get that nothing, nothing, nothing, Here we go!!! type of clutch. You have to really be on your toes to pin this tractors draw bar to anything.
/ 8540 clutch adjustment? #7
My hydraulic clutch is a lot like that and when hooking to something I keep my foot on the brakes for small movements I have adapted to it as have my sons, but it is definitely different than our other tractors.
/ 8540 clutch adjustment? #8
Mine is hydro shuttle also, it too is very touchy. Kind of the "all or nothing" feeling compared to other, older tractors I'm familiar with.
/ 8540 clutch adjustment? #9
Likewise, mine is hydro shuttle and it is definitely all or nothing. My owners manual covers clutch adjustment for syncro shuttle. It is just an adjustment for allowable clutch pedal free travel. It does not indicate any adjustment for slippage or tension. If you have an owners manual it should indicate clutch adjustment but I bet it will be like mine and only for pedal free travel.
Thanks for the replies! I was kinda afraid there wasn't any adjustment to it. Even though I have 1000's of hours operating tractors, I sometimes look like a "noob" when letting off the clutch on this one. Of course my jackrabbit starts only happen when someone is watching... LOL
/ 8540 clutch adjustment? #11
I have been driving tractors for over 55 years and you should have seen me trying ours out on the dealer's lot, if I hadn't been in the back lot they may not have sold it to me.:laughing:
/ 8540 clutch adjustment? #12
so is there excessive play in the clutch pedal linkage? or is your take the clutch is worn w/little engagement to it? is it slipping or grabbing when released? hopefully the previous owner didn't ride it, a sure way to wear it quickly. hopefully just the linkage needs adj. and yes, that can be adjusted with a slight amt. of play after it is engaged. good luck!
2023 Wolverine DM-13-72W Mulcher, Skidsteer Mount (A62679)
2023 Wolverine...
4 Bottom Plow (A65640)
Vermeer RTX 250 Trencher  (A62679)
Vermeer RTX 250...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
