841 lift linkage adj
   / 841 lift linkage adj #1
jp101977
Altoona, Alabama
Ford 841
Hey guys, I have completely gone through the entire hydraulic system on my old 841 and everything works well but I do have one issue. The lift raises and lowers as it should but it doesn't drop as far as it should, I attached my box blade and with the control lever all the way down the box blade barely sits on the ground. Is it possible that I didn't get something in the internal linkage adjusted correctly?
   / 841 lift linkage adj #2
What position is your mode selector lever in - Draft Control or Position Control?
Try changing the mode selector with tractor running and see if the arms go all the way down.
It's in position control,I tried swapping to draft but get the same result
I checked myself this evening and it does drop to the ground when put into draft mode but pops up and inch or two when put into position control
   / 841 lift linkage adj #5
That indicates an alignment of the internal linkage is in order. The I&T FO-20 shop manual gives procedures for making the adjustments without any of the Nuday tools.
Your original post indicates you had previously adjusted the linkage - What did you use for a reference?
If it were me, I would contact Zane to procure his kit that includes an adjustment booklet, feeler gauge, and replacement cam follower pin. Zane Sherman Web Site
49" X 79" EXPANDED METAL RAMP GATE (A51247)
49" X 79" EXPANDED...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
UNUSED JCT 84" HYD ROCK GRAPPLE BUCKET (A51248)
UNUSED JCT 84" HYD...
UNUSED FUTURE CYHC HYD SIDE SHIFT FORKS (A51248)
UNUSED FUTURE CYHC...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
