8400 low hydraulic pressure
/ 8400 low hydraulic pressure #1
Ag Tech740
Somerset, Ky
8400JD
I have an 8400 JD that is only putting out 1800 psi hydraulic pressure. The specs call for 2900 psi. The pump has been replaced with a reman pump. Can the pump pressure be adjusted and if so how is this done? I will be checking pressure and flow at the remotes. What other problems could be affecting low pressure? Thanks!!
/ 8400 low hydraulic pressure #2
:welcome: to TBN
Hope someone here can get involved in your problem.. sorry I cannot help.
/ 8400 low hydraulic pressure #3
I suppose the hitch relief valve could be faulty. I see what I think is shims but they appear to only be available in a kit that's too expensive to experiment with.
key 7 RE39396 Pressure Relief Valve - ADD 310.36 USD
/ 8400 low hydraulic pressure #4
There are 2 different pumps that can be on your tractor. Do you know if the pump is 57cc or 45cc? The adjustments are different on each one.
