821 Power Steering
/ 821 Power Steering #1
Diggerdon1
Marysville, Washington
Ford 860/ Ford 821
I have a ford 821 (1961) that I am rebuilding the power steering pump (EATON Roller vane type). It had a broken pump flow control spring. I can not figure out how to get the spring and balls out of the flow control valve assembly (86534520) . Is there a snap ring that holds them in the valve assembly ?
/ 821 Power Steering #2
Looking at the parts book I cannot see anything that should prevent the valve from coming out once you remove the hex plug.
/ 821 Power Steering #7
Did you try a strong little magnet?
/ 821 Power Steering #8
John, do you know where I can get parts or maybe even an entire pump of the power steering pump in your picture?
/ 821 Power Steering #9
I would start looking with Just8ns.com or dennis-carpenter.com, if you can get in touch with Derick at just8ns he is a real good source of information and might be able to point in a direction to find one.
2022 EZ-GO ELITE...
SCAN TO RECEIVE TEXT UPDATES (A63291)
SCAN TO RECEIVE...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
2004 Lincoln Navigator SUV (A61574)
2004 Lincoln...
2012 Ford E-450 Sewer Viewer Van (A61573)
2012 Ford E-450...
2022 TAKEUCHI TB216 EXCAVATOR (A64279)
2022 TAKEUCHI...
