821 Power Steering
/ 821 Power Steering #1
Diggerdon1
Marysville, Washington
Ford 860/ Ford 821
I have a ford 821 (1961) that I am rebuilding the power steering pump (EATON Roller vane type). It had a broken pump flow control spring. I can not figure out how to get the spring and balls out of the flow control valve assembly (86534520) . Is there a snap ring that holds them in the valve assembly ?
/ 821 Power Steering #2
Looking at the parts book I cannot see anything that should prevent the valve from coming out once you remove the hex plug.
/ 821 Power Steering #7
Did you try a strong little magnet?
/ 821 Power Steering #8
John, do you know where I can get parts or maybe even an entire pump of the power steering pump in your picture?
/ 821 Power Steering #9
I would start looking with Just8ns.com or dennis-carpenter.com, if you can get in touch with Derick at just8ns he is a real good source of information and might be able to point in a direction to find one.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
Cub Cadet Ultima ZT1 Zero Turn Mower (A64047)
Cub Cadet Ultima...
2024 DODGE TRUCK BED (A63569)
2024 DODGE TRUCK...
15K TRIPLEX RADICON PUMP (SHOP BUILT NONE TITLED) (A63569)
15K TRIPLEX...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
