800 $ down the drain ?
/ 800 $ down the drain ? #1
1948berg
Southern Norway
A Fergie-MF 35 gas- Mf 165- Mf 6161- Unimog- Fiat 880
What happends when you tongue is faster then your brain? You buy an old Jacobsen lawn mower for $ 800 from a guy you work with without knowing the production year, horsepower, or the state of the machine. Jacobsen is little known in Norway, parts are probably hard to get.
Any comforting words out there?????
/ 800 $ down the drain ? #2
If it runs well and the engine is in good shape, you probably aren't too bad. What kind of engine is it?
Parts might be able to be found on Ebay
Trying to look at the bright side.
It is a Kohler engine. Notice the starting fluid on the seat!
/ 800 $ down the drain ? #4
Yep can sitting on seat is pretty much telling it all. Most Kohler engines will run a long time as long as there is oil in them. The carbs gum up if old gas is left in the tank. Best to pull the carb and clean the ports.
Starting fluid is really your enemy.
/ 800 $ down the drain ? #5
Just what I was going to ask you (starter fluid) Back in '76 I spent 6 weeks in Denmark, as a student and the honesty really amazed me. -Ed
/ 800 $ down the drain ? #8
In the U.S., Jacobsen turf equipment is used a lot on golf courses. It's considered professional equipment. Often, Jacobsen will purchase products from the OEM and rebadge them with their name. I have a three-wheel dump cart that is a Jacobsen and it was built by EZ-Go. Buying EZ-go parts saves me about 1/2.
If you want to keep and fix that mower, just know that because it's a Jacobsen, the parts will be very expensive, maybe twice as expensive as other products. Look for an engine serial number or a serial number of the mower or both. That number will probably have a code for the date of manufacture. Since it doesn't look too old, it may still have manuals and parts available. It looks like what they call a "rough cut rotary mower" to me.
/ 800 $ down the drain ? #9
I have a Jacobsen out back that looks just like yours, except it has reels instead of a mower deck.
What is wrong with yours? I may have just the part you need, lol. I purchased mine as one of a pair via an online auction. I knew about the two mowers, but was spending my money on the Ford 7710. When the Ford started getting too high, I decided to go after the mowers. I bid on the first, so the auction would extend 15 minutes, but before I got to the second one, which was the running one, the auction ended. So I got the parts machine with the better motor, but not the one that was complete.
Mine has a Kubota diesel in it, by the way and is a model LF-128.
Jacobsen is a Textron Company.
David from jax
/ 800 $ down the drain ? #10
Kohler are good engines. Made in Wisconsin I believe. As long as it wasn't blown up, it should last a long time. The first place I was start is the carb, like WayneB said. If gas sat in it for any amount of time, that is the likely culprit(sp). Take the bowl off and either replace the pin or clean it and the bowl out. You may be able to clean it out if you can get it to run for a second by spraying carb cleaner in the muffler and get it to start that way.
/ 800 $ down the drain ? #11
Winters coming on Gunnar. Perfect project to keep you active till the grass is growing.:D :D
/ 800 $ down the drain ? #12
Sandman, is that motor horizontal or vertical shaft? What size? Would you be interested in parting with it? I am working on a generator project.
Ron
/ 800 $ down the drain ? #13
Ronbo,
Without going out and looking at it, I think it is an 1105 Kubota diesel. That is a horizontal shaft engine with a hydraulic pump mounted via a shaft on one end, and a pulley on the other. This mower is a hydraulicly run monster. Drive wheels, all 7 reel mowers, steering and maybe even a kitchen sink is optional and all run with hydrualics.
Since the original poster was asking about parts, lets see what he is interested in first. Since his is powered by gas, most likely a diesel engine won't be on his wish list.(Shipping to Norway for that would be crazy!) The last person I gave a price to for the engine didn't like it, and I really don't know what it is worth, but I did price it out for $600 a couple months ago. He never saw the motor, and lives further away than you do. If you have seen any diesel engines for sale lately and can send me links to them, I might have something different to base my price on. I have a Steiner with a 904 Kubota diesel in it, so worse case I figured I could always hang onto it as a backup, but something tells me I am not going to wear the 904 out in this lifetime!
I purchased a 10K generator that a guy had a shop up north build, exactly like the generator that Steiner has for my mower. The 1105 is more hp, so it will should run a larger generator easily. I would think that it would be 28 to 33 hp, or something in that range.
I occasionally make trips to southwest Arkansas, via I-49 in La, so depending on your hurry, that might help shipping out.
David from jax
/ 800 $ down the drain ? #14
;) Looks like it would be lots easier on the back than trimmng along ditches and banks with a string trimmer.:D
UNUSED WOLVERINE PFF2-13-45W QUICK ATTACH MAST (A62131)
UNUSED WOLVERINE...
2001 Chevrolet 2500 Service Truck (A63116)
2001 Chevrolet...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63118)
2023 Kubota L3560...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61568)
Pallet of...
