Tires 8.3-24 R4 Max Tire Pressure
   / 8.3-24 R4 Max Tire Pressure #11
i think i also put about 19psi in mine. even with 700 pounds or so on the 3pt there is not excessive squatt, really its just right for biting the ground if your going to pull with it.
   / 8.3-24 R4 Max Tire Pressure #12
No one has mentioned wheather or not they have water in the tires or if it makes any difference?
   / 8.3-24 R4 Max Tire Pressure #14
i have windshield washer fluid in mine till thier full, about 9 gallons if i remember right? and i still keep that much air in them, air pressure is air pressure, the fluid just takes up volume in the tire, i am prettyr sure the tire still compresses the same with or without the fluid as like i said there is still 19psi in the tire in my case
2015 Ford Fusion S Sedan (A54815)
2015 Ford Fusion S...
CRAFTSMAN PUSH MOWER (A58374)
CRAFTSMAN PUSH...
CATBKTSSL_78 (A55787)
1994 Blue Bird Command Center Bus (A55973)
1994 Blue Bird...
1998 INTERNATIONAL 9400 (A58214)
1998 INTERNATIONAL...
Electric Sweeper W/Pressure Washer, Water Hose, & Mister (New/Unused) (A59225)
Electric Sweeper...
