Tires 8.3-24 R4 Max Tire Pressure
   / 8.3-24 R4 Max Tire Pressure #11
i think i also put about 19psi in mine. even with 700 pounds or so on the 3pt there is not excessive squatt, really its just right for biting the ground if your going to pull with it.
   / 8.3-24 R4 Max Tire Pressure #12
No one has mentioned wheather or not they have water in the tires or if it makes any difference?
   / 8.3-24 R4 Max Tire Pressure #14
i have windshield washer fluid in mine till thier full, about 9 gallons if i remember right? and i still keep that much air in them, air pressure is air pressure, the fluid just takes up volume in the tire, i am prettyr sure the tire still compresses the same with or without the fluid as like i said there is still 19psi in the tire in my case
PALLET OF 250 TRAFFIC CONES (A58214)
PALLET OF 250...
2004 PETERBILT 379 (A58214)
2004 PETERBILT 379...
2014 DODGE RAM 2500 (A58214)
2014 DODGE RAM...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
2022 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2022 Caterpillar...
500BBL FRAC TANK (A58214)
500BBL FRAC TANK...
