7TL Loader Capacity
/ 7TL Loader Capacity #1
Vraz
Does anyone have a lift capacity to 1.5M @ 500mm for the 7TL? Trying to understand how it stacks up against the JD 300CX. Thanks.
/ 7TL Loader Capacity #2
Going off memory, I think it is about 1600 at pins and a couple hundred less at the end of the bucket.
/ 7TL Loader Capacity #3
it should be listed on the Bobcat CUT website
Lift Capacity to Max. Height At 500 mm forward of pins 1225 lbs
Actually, I was specifically looking for lift capacity @ 1.5M high, not at max height. On paper, the 7TL (1225lbs 500mm forward at max height) looks to outperform the 300CX (1047-1122lbs 500mm forward at max height) and rivals the larger 8TL (1300lbs 500mm forward at max height). That is surprising given the 7TL has the lowest breakout force of the bunch (1904 vs 2416/300CX and 2511/8TL).
Suspect that since the 7TL is the shortest @ 7' vs 300CX @ 8.5' and 8TL @ 8', that may explain the difference. Have seen other manufacturers publish load capacities for a height of 1.5M and assume that is a better comparison metrics when the max height differs.
