Backhoe 7TB Finally Arrived
/ 7TB Finally Arrived #11
Thank you - great info and clear! I was going to experiment and you sped up the process. The fewer the items to remove/install, the better. The stuff gets heavy too. Do you leave (if you have it on in the first place) your draw bar on the tractor? Looks like it will not interfere either.
Thanks again.
You're right ... the draw bar is still in place and does not interfere. I've chosen to reverse it like suggested when not in use but when I got it it was in the regular way and no problem. I'll take a pic tomorrow ... I was using the tractor this evening and I forgot ... :rolleyes:
/ 7TB Finally Arrived #12
I have the 7TB and in hindsite I've been much more satisfied with a Woods X70 or even X80. The bolt on subframe assembly of the Woods does away with the monstrosity of hardware attached to the 7TB. Its the length of a small car when detached. Mounting a Woods is far more easily done, too. Pins attach to the subframe on the hoe which is lifted on under its own hydraulic capability.
/ 7TB Finally Arrived #13
There are trade-offs in both styles of sub-frame. Fixed mounted to backhoe does take up more storage space, but leaves tractor with its normal ground clearance when removed. How much of an advantage or difference in ground clearance depends on make, model, and owners use. The fix mounted to tractor/removed at backhoe is opposite, it requires less storage room when off but leaves ground clearance the same.
What surprises, with all the ingenious customizations I've seen here in TBN, is no one has come up with a dual style sub-frame. One that can be disconnected at either point, or at least make a hinged frame that when removed with the hoe it can be hinged up and locked in vertical position for less storage space.
I don't have a backhoe, but if I did I would be looking at this real seriously.
/ 7TB Finally Arrived #14
That would be a great idea! :cool2:
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
Willmar 4550 Wrangler Articulating Loader (A61307)
Willmar 4550...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
