790
Anonymous Poster
Epic Contributor
I'm going to look at a used 790 (100 hrs) this afternoon and need to know what you think of the 790, pros and cons. How does it compare with the orange and blue ones?It has a factory FEL and I plan to use it for general property work and some snow removal. Thanks
From what I have heard from people who've used them, they are nice, but are a little cramped. They are JD's economy tractor, so they are less expensive than a comparable 4000 series. You should also be aware that though it is in the 35 HP range, it's hydraulics are a little weak for the size. I guess it depends on what you want to use it for. I don't believe Deere has a hoe for it. I think it is a nice little estate tractor though.
Purchase my 790 late November 2001, have little over 56 hours an no problems... The 790 can handle a 6 ft snow blade, 5 ft bush-hog and 72 inch finish mower without any undo strain. The snow blade I have is a Curtiss, it goes in place of the FEL bucket, 4 pins. It's a breeze to mount for two people but doable for one.. For ease of changing implement, both my mowers are rear mounted, takes a little getting used to mowing around trees an tight places but you adjust.
If not already equipt with a mid-PTO, one can be added for under $400 dollars. I've been told
the 790 will handle a 72 in mid-mounted mower deck without FEL removal..
You'll love the direct injection engine, it starts like a gas engine down to near freezing..
Below freezing you'rll need to use the air induction heater, 20 seconds an it's go...
The only draw back is Deere doesn't off the 790 with a HST drive. If you plan on doing a lot of
loader work a HST is desirable. For most other applications the gear drive is fine. With 8 sp.
it's hard not to find one that is suitable...
If you feel you need HST, check out New Holland's TC 30, it's almost a twin to the JD 790.
Just about the same size, weight, power an price but the NH offers HST.
The JD 790/NH TC 30 tractors are possible the best value in that size tractor today, no frills
but everything you need to get the job done..
PROS:
It is marketed as "no-frills" but JD has to contrast it against the latest and greatest. There are a lot of little features that I like in this tractor.
1) The engine is immensly accessable -- I was amazed how easily I was able to change the fan belt for example.
2) Safety features are as good as any make or other compact. For example, it has PTO and transmission operator presence systems.
3) Relative to the Kubota L3010, I think the drivers compartment is very comfortable.
4) It is well made and the bugs seem to be removed.
5) Dual stage clutch. 4WD is shift-on-the-go engagement.
6) Engine starts immediately - direct injection - auto bleed. I've never had a problem even in below zero weather.
7) dual hydraulic pumps (on 4WD) provide constant flow of oil to both power steering and implements.
8) Selectable PTO allows operation of the mid-PTO, rear-PTO, or mid- and rear-PTO together. Don't know about Kubota or NH here.
CONS:
1) 3PH lift capacity a bit weak relative to Kubota and NH. I have never found this to be a problem though -- I tow a rough cut mower, a 715 lb. 54" tiller through clay with blades traveling in reverse, a PHD and a 65" Woods scraper.
2) Lift capacity of FEL a bit weak relative to Kubota and NH. P.S. Lifting a load of wet pond muck is no problem. Maybe a problem if you are in a hurry to remove a stump.
3) The battery terminal connectors are inferior.
Good luck!
Buck
Re: 790 - Backhoe info
IHCrules,
Here is info (attachment) on the JD 790 backhoe.
Buck
Great tractor. I have owned mine for a year, now. I own a land scaping company and use my FEL all the time. It is what you get used to. I can move 16 CU. Yrds. of dirt in about 25 minutes with it. I rotary mow with a JD 513, have a 60" woods box blade, a 72" landscape rake, a 60" tiller and a 72" grader blade. The 790 handles all of these implements with no problem. The back lifting capability was designed that way on purpose, I believe because of the way the tractor is designed. The front end is a little light without a FEL. Go over a bump with your rotary cutter attached with no FEL on and you will know what I am talking about. The tractor is light enough to go in areas of turf without damaging the turf or making ruts in the soil. I can't really thing of any cons, ecept when it is 97 deg. outside and I am rotary mowing a 30 acre field. Then, I want a cab with A/C and a 15' bat wing mower, which we all know, you can't get on a 790, and it doesn't have the HP to move anything more thatn a 5' rotary.
I bought my 790 two years ago with 35 hours. Overall, I have to agree with Gunfighter's assessment of the 790. I use mine for mowing, post-hole digging, and general loader work.... no complaints overall, all though a little stronger loader would be nice. I'm a pretty hefty guy (240) and don't seem to have any trouble getting in and out of the "cockpit".
Good luck with your decision,
Henry
To all:
I'am 290 lbs 6-2 not anymore cramped than the other colors.
This tractor is true VALUE...If you are looking for bells and whistles go for the 4000 series..
Hydraulic specs are a little misleading....This tractor will pick up most any machine you would ever run behind a 30 hp tractor....the lift specs are listed from a point 24 inches behind lift link balls. The other colors are in many cases giving lift spec at lift point or are using shorter lift links. They will offer long reach links as a option. I have seen box scraper teeth hit rear tires on some tractors....No problem with 790...
Buy the 790 and have fun using it.
edv
Nick, did you get out to look at the 790? I'm a bit late to this thread and it appears everyone has covered the 790 pretty well. I've got just over 100 hours on mine and absolutely love it. Brush cutting, grading, FEL work and stump removal have been my main chores to date. The 790 does them all well. Sure, a bigger tractor would do more faster, but then you're paying a lot more money for it. My only complaint is the battery terminals. Other than that it's a great value in a tractor /w3tcompact/icons/smile.gif
I have owned a 790 for a couple years ... have over 250 hrs on it without the first problem ... If the hydros were much stronger you would turn it on is nose or perhaps on the other end ... When I have tried to work without rear weigh I have raised the rear when lifting heavy mat'l (like a fallen 18" tree)
... I have used it to snake logs, change drainage around the house (FEL work and Box Blade) ... I use a 513 rotary mower and have cut 1-1/2" - 2" brush .... If it has a short coming that I am concerned about it is working on a slope ... I use a 6 ft. finish mower and on a steep slope and I have raised the up hill side tires and now I no longer cut that area with this tractor ... I use a much larger one for that area ... This is a very smooth and dependable tractor after you replace the battery cable ends ... I choose it over the 4000 series and have no regerts ... the 4 wd is a necessary item on a small tractor if you have the need for the "power" and I could not be without it ... I find myself in 4 wd almost all the time ...
The 790 has 30 HP and 25 PTO HP.
The lift cap. of TC 30 is 1653# 24" aft of hitch.
I think industry std. is 24" back for lift ratings.
All the JD and NH ratings are anyway.
em14,
Why is it that 790 owners always appear to justifying their tractors?
I don't get it.
Buck
Buck,
I was also trying to answer the Posters question which started all of this ... Maybe instead of telling him what my experinces have been I should have just said " It's a very good little tractor with a few short comings due to its size when it comes to side hill use"...
em14,
I was being sloppy. I did not mean to focus on your post with that question, rather, I was trying to ask the 790 population as a whole. I intended to address the question to the root poster. I am sorry!
Buck
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
23.1-26 Tires - Set of 2 (A68134)
23.1-26 Tires -...
2024 CATERPILLAR 299D3 XE SKID STEER (A65056)
2024 CATERPILLAR...
2014 INTERNATIONAL DURASTAR 4300 26FT NON CDL BOX TRUCK (A69167)
2014 INTERNATIONAL...
2011 MAGNUM TRAILER LIGHT PLANT (A67714)
2011 MAGNUM...
