790 clutch spring???
/ 790 clutch spring??? #1
uptaker73
Morganton, NC
RK 37, John Deere LX280 John Deere Z535m John Deere 160
Was out today doing a few driveways for family and friends and while doing my mothers I noticed my clutch got real soft. I thought oh no my clutch is coming out. It just didnt feel right but it operated with no problem. Finished it up loaded the tractor went to the next job and my mother called and said she found a spring out in the driveway with one of the clips broken off. Bingo I figure that is what I felt How important is this spring. I dont even see where it goes. But I'll crawl under it tommorrow to look again. I appreciate any help.
/ 790 clutch spring??? #3
hey my broke a few weeks ago had to remove shield between foot rest . One end hooks on bolt sticking out side of transmittion other end hooks in hole on petal about half way back of petal and where it piovots.Near 4+4 lever look hard for the little hole its there good luck Tim also spring was about $6.00
/ 790 clutch spring??? #4
/ 790 clutch spring??? #5
Yeah there is a spring, just look right above where you grease the clutch pedal under the left hand foot rest and you will see where it attaches to.
/ 790 clutch spring??? #6
It will be at least a week before I can get one. It seems to be doing ok without it. Will I damage something if I continue to use it until I get one.
/ 790 clutch spring??? #9
The spring you are referring to is the clutch pedal return spring. It pulls the pedal back far enough that the throw-out bearing does not rest on pressure plate fingers. Short term use like this should cause no problems. I would not recommend putting it off too long since it is causing a little extra wear and tear on throw-out bearing. Now would be a good time to check your free travel also. Without the spring, you should be able to pull back on your clutch pedal a half inch or so. If you have no mvement back on the pedal, you definitely need adjustment. The adjusting rod is under left step also. It is easiest accessed by removing left step. Good Luck!
/ 790 clutch spring??? #10
/ 790 clutch spring??? #11
Same thing happened to me over a year ago. As someone else mentioned, it's just the pedal return spring, not the actual clutch springs. Mine broke on a Sunday so I hit Home Depot for the closest thing and it's still going strong. Maybe next time I'll "spring" for the JD part? (Sorry, couldn't resist)
And yes, it was a pain to replace /forums/images/graemlins/smile.gif
/ 790 clutch spring??? #12
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
2024 8R 370 Tractor (A63111)
2024 8R 370...
2015 HYUNDAI HX220L EXCAVATOR (A64279)
2015 HYUNDAI...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01109 - Arrangement 385-7728 - Pump Takeout (A63689)
Caterpillar C18...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
