7710 Ford steering issues
   / 7710 Ford steering issues
Thanks rick you were right on that part number. How the **** did u know that? my number crossed to your number. thanks!!!!!
Thanks to everyone. New pump fixed the problem! now have an issue with 4wd i will start a new post
Follow up question: The steering is much improved however it is still hard to turn when sitting still. I checked the pressure at pump and it around 1100 psi. It seems to get harder to turn the longer(warmer) I drive it
   / 7710 Ford steering issues #14
Getting the steering to operate while standing still requires more effort than when traveling. Front weights add increased resistance as well. Has anyone greased the front spindles lately? Quite often people think they have a power steering problem and it turns out to be rust and crud buildup in the spindles where grease SHOULD be.
good thinking. I already greased everything when i first bought it a month ago. the pump whines as well
   / 7710 Ford steering issues #16
Old topic, but I have a similar issue. Can someone point me where I need to fill the steering fluid?
   / 7710 Ford steering issues #17
You're talking a 7710? Left side of engine, barrel tank with a silver dollar sized cap. Fill with hydraulic fluid to lower edge.
   / 7710 Ford steering issues #18
Awesome! Found it. After reading many threads on the subject, I'm thinking about adding some fluid and see if it makes any difference. It has been working great since I bought it, but last week my neighbor used it to load some hay bales and it's been acting up since then. While I don't see any leak around the steering hydraulics (my bucket loader leaks though), would it be safe to add some steering repair fluid like "Bar's Leaks Power Steering Repair Fluid" to troubleshoot? Thanks for all your help!! I'm new to tractors... :)
1957 Chevrolet Bel Air - 2-Door Hardtop, Period-Correct Engine (A56435)
1957 Chevrolet Bel...
24in pin on excavator tooth bucket (A56435)
24in pin on...
2023 Kubota Z252KH-54 Zero Turn Mower (A56435)
2023 Kubota...
2017 Ford F-350 Flatbed Service Truck (A56858)
2017 Ford F-350...
1999-2010 Ford Pickup Truck Bed (A55973)
1999-2010 Ford...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
