7610 Rear axle squeak
   / 7610 Rear axle squeak #1
53gravely
NJ/VT
Kubota 7610 HSD
My 7610 has developed a squeak whit each revolution of the rear wheel. It started in the fall and I put a breaker bar on the cinch nut and tightened it. It didn't take long for the squak to return. (I think having the rear chains on may have something to do with it)
I called the dealer service manager and he mentioned that between the hub and the hex axle are some sort of shims. He suggested maybe rotating the shims to the next set of flats on the axle. I'm gonna put the neighbor's impact gun on it and crank the @#$% out if it.
Anybody have any thoughts on this? Experience? Tricks?
If it begins again, I guess I'll have to cough up the $130 for a new hub...or do I just need the shims? What do I look for?
   / 7610 Rear axle squeak #2
Keeping all the hub bolts tight are the best I can tell you! The longer you run them loose, the closer you are to buying hubs and possibly axles!
Jacked 'er up and pulled the rim/loaded tire (even that little tire is heavy when loaded!)
The cinch bolt was loose again. I put a 4 ft breaker bar on the 3/4 drive and cranked it. If it happens again, I'm breaking out the red lock-tite.
   / 7610 Rear axle squeak #4
I also had a squeak on my 7510, everything was tight......dealer put grease on the hex shaft....took care of it...Everything is tight too...
   / 7610 Rear axle squeak #5
The cinch bolt on my 7500 loosens up every 6 months or so. If I position the tractor right, I can reach in there with a wrench and tighten it up without taking the wheel off.
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2005 Morgan Corporation Flatbed Body (A50854)
2005 Morgan...
2013 MACK GU713 (A50854)
2013 MACK GU713...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
2011 MAGNUM PRODUCTS LIGHT TOWER/WATER TANK TRAILER (A50854)
2011 MAGNUM...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
