7600 Lumen LED Worklight Install
/ 7600 Lumen LED Worklight Install #21
Are you allowed to go into the traffic with these lights? But, anyway, you said polices are your friends:).
I am about to buy such a light, 100 watt, for street lightening and I found out that the prices are around 1-1.5 USD per watt. So, you paid 70-80 USD for your about 50 watt led? Or, more? to sponsor America (whoever they are - nba? ok, just joking.)
/ 7600 Lumen LED Worklight Install #22
You're question is to someone else but I thought I would pipe in on the thought...I installed two street lights on my drive a few years back and recently replaced the fixture and bulb with a high efficiency bulb that uses much less amps with similar watt output. I found it to be worth the small investment to gain the usage efficency.
/ 7600 Lumen LED Worklight Install #23
To say LEDs don't use much wattage is not exactly correct... Watts is more of a matter of output. LEDs do, however draw very few Amps (current). These LEDs draw 4 amps each, and in a 12 volt system, using the equation Watt = Amps x Volts, the output is around 48 watts output per lighthead.
Wattage and amperage are directly related if voltage stays the same. These are input values not output. Light output is measure in lumens and you get many more lumens per watt with LEDs than an incandescent. Great for us who have tractors with small alternators.
Nice lights. I would knock them off in the woods and would have them better protected for what they cost.
/ 7600 Lumen LED Worklight Install #24
Nice looking lights but they need to come down to under $100 a set before I'll be upgrading. At $25 a piece I'm not going to be crying when a tree limb takes out one of my 55w Hobbs Halogen lights.
/ 7600 Lumen LED Worklight Install #25
Great lights. I graduated from the Acadamy of more is better and bigger is great. Love those lights. On the Gator I got my wife for Mothers Day, I had every light JD had for the unit put on. I can blind deer on my 50 acre field from front to back. If I could strap on more I would but dont think the alternator would hold up.
UNUSED WOLVERINE HYD SNOW PUSHER (A64281)
UNUSED WOLVERINE...
2010 CHEVROLET PICKUP 3500 HD 4X4 CREW CAB (A59912)
2010 CHEVROLET...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
4' 3pt Dirt Scoop (A64119)
4' 3pt Dirt Scoop...
Athens Harrow Scrapers (A64119)
Athens Harrow...
