755 power steering problem
/ 755 power steering problem #1
RegWaters
SC
JD755
I've got a nice hydraulic leak from the power steering. It doesn't occur all the time and not at full lock. I'll just be putzing around and notice a nice stream of hydraulic fluid coming from under the steering wheel running down the column. I suspect a seal is bad. I don't have a shop manual. Has anybody worked on a power steering valve. Is it difficult ? Should I just relegate it to the local dealer. I plan on ordering a manual Monday. I've got all the covers off and it looks like a bear to get to. Any insight would be appreciated.
Reg In SC
Just got it apart, 4hrs later, must have saved $500 labor. I wouldn't do it for much less. Seems to be end and radial play in the steering column. I'll head to the dealer monday to check on a spare or rebuild kit. I'm not going to tear it apart until I find out if there is a core exchange on a rebuilt one. Nothing like getting to know the innerds of your tractor.
Reg in SC
Just a few pics, trying out the digital camera.
She's outa there !!!!!!!!!!!!!!
/ 755 power steering problem #5
Good job......you saved yourself a lot of $$$$$$$$
/ 755 power steering problem #6
Boy, I'll tell you, I'd be scared of that amount of tear down without the manual - or did you get the manual before the tear-down?
So, did you replace or rebuild? How much did that run you? Did the dealer tell you what it was for him to do all the work?
mark
/ 755 power steering problem #7
If you haven't gotten your manual yet...
Power Steering Valve Assembly for 755
JD Parts Breakdown:
KEY PART NO. PART NAME QTY SERIAL NO. REMARKS
1A AM103066 CAP 1 XXXXXX- (USE WITH M71094 STEERING WHEEL)
1B M46707 LABEL 1 -XXXXXX (USE WITH M85416 STEERING WHEEL)
2 M85417 CAP 1 -XXXXXX (USE WITH M85416)
3 T11220 O-RING 1 -XXXXXX (USE WITH M85416)
4 14H866 NUT 1 5/8"
5 M85416 STEERING WHEEL 1 -XXXXXX (SUB AM103066 AND M71094)
M71094 STEERING WHEEL 1 XXXXXX- (USE WITH AM103066 CAP)
6 AM39469 KIT 1 SPRING (PKG. OF 6)
7 AM39464 VALVE 1 ALSO RING ASSEMBLY
8 AM107078 KIT 1 SEAL (INCLUDES FACE SEAL, RING SEAL, BACKUP
SEAL, O-RING AND SEALS)
9 M85304 MANIFOLD 1
10 M83389 LOCK NUT 4
11 ........ SPRING 1 (SUB AM107780)
12 AM107780 VALVE 1 (SUB FOR AM103361)
13 M89669 O-RING 1
14 AM107779 PORT PLATE 1 (SUB FOR AM101633)
15 ........ PLATE 1 (A) (SUB FOR M85291)
16 ........ ROTOR 1 (A)
17 M71745 SPACER 1
18 AM39460 KIT 1 NEEDLE ROLLER (PKG. OF 9)
19 AM39462 COMMUTATOR HOUSING 1 COMMUTATOR AND RING ASSEMBLY, (ORDER
AM101948)
20 M85289 COVER 1 COMMUTATOR
21 ........ CAP SCREW 11 (A) (SUB FOR M71744)
22 ........ STEERING METERING PUMP 1 (A)
23 M85287 RING 1 METERING, (ORDER AM101948)
24 M85290 LINK 1 DRIVE, (ORDER AM101948)
25 ........ MANIFOLD 1 (A) (SUB FOR M85295)
26 AM39465 DRIVE 1
27 M85284 SPACER 1
28 M71743 BEARING 1
29 M85283 SPACER 1
30 M85282 KIT 1 UPPER COVER PLATE (4 PCS.)
31 M40514 SNAP RING 1
32 AM39498 SHAFT 1 INPUT
33 M86793 WASHER 1
34 M87133 BOLT 4
35 AM107081 KIT 1 COLUMN BEARING
36 AM39456 COVER 1 (INCLUDES CUPPED WASHER)
37 AM101948 STEERING CONTROL UNIT 1 (MARKED HGF08004) OR (HGF08004-A1) 4 PORT
VALVE (INCLUDES (4) T77613)
38 14H650 NUT 4 5/16"
(A) NSEP, ORDER AM101948
/ 755 power steering problem #8
Reg,
Here’s the rest of it:
PC 2054-655, 755, 756, 855 AND 856 COMPACT UTILITY TRACTORS HYDRAULICS
POWER STEERING CYLINDER AND LINES
6 7 8
5 5 5
KEY PART NO. PART NAME QTY SERIAL NO. 5 5 5 REMARKS
1 T77613 O-RING 2
2 AM101993 OIL LINE 1 X
AM101987 OIL LINE 1 X
AM105486 OIL LINE 1 X (SUB FOR AM101981)
3 AM101992 OIL LINE 1 X KIT
AM101986 OIL LINE 1 X
AM105487 OIL LINE 1 X (SUB FOR AM101980)
4 M42858 CLAMP 1 -XXXXXX
5 R42009 CLAMP 1 -XXXXXX
R42009 CLAMP 2 XXXXXX-
6 M40333 LOCK NUT 1 -XXXXXX 6.350 MM
24H1287 WASHER 1 -XXXXXX 9/32" X 5/8" X 0.065"
14M7166 LOCK NUT 1 XXXXXX- M8
7 T77814 O-RING 2
8 AM102817 ELBOW FITTING 2 45 DEG
9 AM102816 FITTING 2
10 M91486 HOSE 2 (CUT FROM 10' M91486)
11 T77814 O-RING 2
12 38H1003 ELBOW FITTING 2
13 R28782 O-RING 2
14 11M7015 COTTER PIN 2 3.200 X 25 MM
15 14H862 NUT 2 9/16"
16 M121112 COVER 2
17 AN122518 FITTING 1
18 AM108898 HYDRAULIC CYLINDER 1 X (SUB FOR AM105772)
AM108897 HYDRAULIC CYLINDER 1 X X (SUB FOR AM105773)
19 JD7769 LUBRICATION FITTING 2
No Manual, just used the pattened grey tray method. Break the job into a series of smaller jobs and each small job gets its own parts tray. As long as I don't have to wait 3 weeks for the part I'll be OK. Did have to jot down the wire color code on the console indicator lights and the configuration of the hydraulic hoses. Also I spent the first 1hr just looking !!!.
John thanks for the exploded view, unfortunately this looks like an expensive part. I'll check the dealer Monday to find out my options.
Reg in SC
Got her back together this morning. Seal kit ran $45.00 complete unit would be $580.00 . Those little spring got pretty hairy. The hardest part was stacking all those plate together and trying to bolt it up without it flying apart. Still got the fenders off, gonna hit the rust spots and give em a touch of paint before I bolt them back on. Took the oportunity to change tranny & engine oil/filter and hit all the zercs. she purrs like a kitten. Did notice the engine oil was pretty black. I bought the tractor in August at 315 hrs. and the owner said it had just been serviced 1st of the summer . The oil looked pretty bad for just 35 hr. ( now at 350 hrs. )
Reg in SC
/ 755 power steering problem #11
What is the best way to get to the manifold at the end of the steering column? I've got a broken hydraulic line.
300 GAL WATER TANK (A68842)
300 GAL WATER TANK...
2018 SKYJACK  SJ843TH (A67714)
2018 SKYJACK...
2006 Ford F-750 Terex Commander C4047 Digger Derrick Truck (A68183)
2006 Ford F-750...
PALLET OF 2 SHOP VACS AND SHOP BROOMS (A68842)
PALLET OF 2 SHOP...
2015 PETERBILT 389 T/A 6X4 SLEEPER TRUCK TRACTOR (A69167)
2015 PETERBILT 389...
1987 Fruehauf MC 307 Insulated 7,500 Gallon T/A Chemical Tanker Trailer (A68183)
1987 Fruehauf MC...
