755 fwd 3cylinder diesel,Compact utility tractor
   / 755 fwd 3cylinder diesel,Compact utility tractor #1
BLC755
blc4570@yahoo.com
What would cause glow plug light to stay on after starting? Bob
   / 755 fwd 3cylinder diesel,Compact utility tractor #2
Going to guess a little here........
On my 855 the pre heater light cycles for about 30 seconds or so.
I wonder if you start the motor before that time is up it continues to finish its cycle ?
Or if it stays on a significant amount of time after starting, that could be a problem with the timer ??
Good luck
   / 755 fwd 3cylinder diesel,Compact utility tractor #3
On my 955 it will stay on and finish the cycle.
Ed
Hello! Here's my problem 755 engine began getting harder to start! Checked glow plugs working but installed new ones! Still hard to start had to boost battery every time cranked and cranked finally would start ! Then wouldn't start at all! Fuses good fuel shutoff solenoid working! A lot of light gray smoke then wouldn't start at all crank an crank nothing replaced injectors still nothing about st my wits end with it!!!! Help
   / 755 fwd 3cylinder diesel,Compact utility tractor #5
Check you glow plug control module also Time delay module on some diesels. I would also get the TM manuals.
Tractor TM1360
Parts Catalog PC2054
Engine CTM3
Drive Axles CTM4820
Get the CDs, they are half the price of the paper manual from dealers
Thanks I think it only has a glow plug relay on firewall. I think there around 70 bucks
   / 755 fwd 3cylinder diesel,Compact utility tractor #7
You said you put in new glow plugs and that they are working ----- you did say that, correct. I'll assume that there isn't any need to ask how you know. Beyond that, a diesel needs fuel, compression and air. Check all three --- clean fuel filter? Clean fuel?? When you replaced the injectors, did you bleed the fuel system through the injectors?? Clean air filter??? What's the compression ---- should be around 450 psi or so?? If all three are good and nobody messed with the engine timing, it will run.
   / 755 fwd 3cylinder diesel,Compact utility tractor #8
I have a PDF of the Deere tech manual you're welcome to, if wanted shoot me your email
Joe
378634 (A51573)
378634 (A51573)
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
Guard Rail Joints (A51692)
Guard Rail Joints...
2015 INTERNATIONAL PROSTAR TANDEM AXLE MID ROOF SLEEPER (A52577)
2015 INTERNATIONAL...
1997 National RV Tropi-Cal Motorhome (A51694)
1997 National RV...
