755 60" MMM Adjustment
/ 755 60" MMM Adjustment #1
fishmen222
Carson, VA
John Deere 755
Bought three manuals, but figured I could get by without a deck manual...wrong. The deck in full up only moves about 2" at best. Adjustment knob works fine. My question is on the attachment arms. I have seen many examples on here, but not mine. On the left side is a turnbuckle with about 1.5" of adjustment left. The right side has a split arm with about a 3" top mount slot in it. Is the turnbuckle to just even the deck, or can I adjust the raised heigth with just the one adjustment?
Thanks!
/ 755 60" MMM Adjustment #2
I have a 60" deck on my 855.
The crank handle on the floor board, left side, is the amount of total up and down the deck will move. I run mine about 6 turns from all the way up.
Yes The turn buckle is to level the deck if needed.
That's my best guess anyway......
Good luck
Found it. Wrong lift links. 4" too long. Sould have noticed the links bottoming out in the slip slots,but I was too busy looking for mechanical causes. Made some out of chain and clevises until I can fabricate some real ones.
/ 755 60" MMM Adjustment #4
I'm searching the forums right now and I think I have exactly the opposite problem.
I am in the process of buying a 60" mower for my 855 and the lift links are too short. I know they are different between the two.
I'd absolutely trade you for your longer ones and then we'd both be happy.
Message me if you're interested.
Otherwise, does anyone know where I can find the right attachment hardware for a 60" deck on an 855?
Eric
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
1983 Mack DM492S Cab & Chassis (A62679)
1983 Mack DM492S...
2016 Ford Taurus Sedan (A64194)
2016 Ford Taurus...
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
Covered Livestock Mineral Feeder (A66408)
Covered Livestock...
