7520
   / 7520 #1
Rambelinman
Mahindra 7520
I have a 7520 4 -wheel drive I bought new in 06. It now has 590 hours. It started to run rough so I thought it may be the filters, replaced but did not help. It will not idle below 1500 rpms without dying sounds just like it has a little miss and the engine pulls down fast when even trying to pick up the bucket. Noticed the injecter pump was hot to the touch even after a few minuites of running. Oh and when I give it full throtle it winds up slowly but does not govern it self at the redline, any ideals what may be wrong with it?
   / 7520 #2
You may have a suction leak in the fuel line. What filters did you change?
larry
   / 7520
Both of the fuel, thanks I will check that out.
   / 7520 #4
Check the air filter. They can collapse and choke intake if they get really dirty.
larry
   / 7520
Did that, a service teck said to check the banjo fitting on the pump for trash inside or a bad fitting, still hopefull not the injecter pump,
   / 7520 #6
Not likely at that low of hrs. Also look for a pinched fuel line. That has happened to me.
larry
   / 7520
Pulled air filters, checked fuel lines, even pulled lines from tank, removed banjo fittings, still does not run right, guess time to get a mechanic to look at it, thank you Larry, I can't think of anything else to check, but the two selonoids get hot, pulled the one easy to get to no trash in it.
2025 GIYI Single Cylinder Hydraulic Grapple Stump Bucket Skid Steer Attachment (A50322)
2025 GIYI Single...
2009 Hyundai Sonata Sedan (A50324)
2009 Hyundai...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
2022 John Deere 6135E (A50120)
2022 John Deere...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
Cat 953C Crawler Loader (RIDE AND DRIVE) (A50774)
Cat 953C Crawler...
