7520 preheater not working, EMERGENCY!
   / 7520 preheater not working, EMERGENCY! #21
A tarp and a heater will actually work. I will tell you that through the years, folks have actually built fires under engines to get them started.
I would say that if you cannot afford a heater that cost under 40 bucks and the power to use it then perhaps you have more issues than getting the tractor fired up.
If my tractor won't start today, a "field expedient" measure that gets it going is just the ticket.
The block heater may only be $40, but installation is more. If someone wants to self-install, this is a job best done in the summer, instead of outside in weather too cold for the tractor to start.
As far as building a fire, I once had a beater Dodge van which was hard to start in winter. If I lit two charcoal briquettes in an old sauce pan I could put them under the oil pan and go back in for a cup of coffee. 20 minutes later it started every time. That was when I was young and foolish. Today, I would use an electric heater.
   / 7520 preheater not working, EMERGENCY! #22
You're right, it's lot more fun in the summertime, but having done it in the wintertime (10F, brrrrr) I can say it's no big deal. It took about 15 mins and I only lost a few ounces of coolant. We found our heater at the local farm&fleet.
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A59230)
2012 Ford F-350...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED FUTURE PC71-71" HYD PLATE COMPACTOR (A60432)
UNUSED FUTURE...
2014 CATERPILLAR CB24B DOUBLE DRUM ROLLER (A60429)
2014 CATERPILLAR...
