7500 or 2410?
/ 7500 or 2410? #1
Anonymous Poster
Epic Contributor
I started looking at the BX2200, then the 7400 and after help and reading I won't settle for less than the 7500. I have read many of your posts and wonder if I can justify paying more and get the 2410. My questions are, what is position control you talk about? Does 3 horsepower more make that much of a difference? Is the 2410 any bigger than the 7500? Are there any other features I am missing that make the 2410 about $2500 more? I do understand the FEL will hold about 100 pounds more, what have I missed? THANKS for your help, I'm getting close.
/ 7500 or 2410? #2
<font color=blue>what is position control you talk about?</font color=blue>
The B7500 has a joystick for the 3PH with three positions: 1=lower/float, 2=hold, 3=raise. The B2x10 have postition control with graduated markings for position. Put the lever in the "position" you want. It holds there.
<font color=blue>Does 3 horsepower more make that much of a difference?</font color=blue>
That depends. Doesn't sound like a lot, but on a percentage basis, it's about 15% more.
<font color=blue>Is the 2410 any bigger than the 7500?</font color=blue>
A little bit wider, taller and longer. Check the specs for the exact amounts.
<font color=blue>Are there any other features I am missing that make the 2410 about $2500 more?</font color=blue>
Well, because the 2410 is bigger, it also weighs more than the 7500. I guess the way to think about it is the same as the 15% power issue. Probably about 15% more tractor? Hmmm. $2500 is about 21% more price./w3tcompact/icons/smile.gif
The GlueGuy
/ 7500 or 2410? #3
4WheelRider,
This topic has been flogged pretty well on this forum - check the archives if you haven't already.
I'll add a few items to Glueguy's very good summary: Loader lift capacity is between 16% and 22% higher for the B2410 (depending on center of bucket or pivot point). Three-point hitch lift capacity is 22% higher on the B2410. According to the manufacturer's specs, the B2410 is rated to handle a little larger tiller and finish mower. The seat on the B2410 is a little nicer, and the fenders are metal (v. plastic on the B7500). The mid- and rear-PTO are independent on the B2410, but not on the B7500 (I think).
One item in the B7500's favor is hydraulic capacity - identical on the two machines.
Hope this helps.
/ 7500 or 2410? #4
Wheeldog,
<font color=blue>plastic on the B7500</font color=blue> My wife assures me her tractor does not have plastic fenders. Also the rear pto runs all by itself, and the rear runs when the mid does./w3tcompact/icons/smile.gif
/ 7500 or 2410? #5
Can't comment on the PTO, but do know for certainty that the 7500 that I sat on a few weeks ago had a substantial amount of plastic on the fenders!! Going to the B2x10 series gets rid of that.
Kevin
/ 7500 or 2410? #6
Kevin,
You don't suppose my wife talked that dealer into some special metal fenders do ya?
The lever guide and marking plates on the fenders are plactic but I think thats pretty common across the B series, if thats substantial OK.
<font color=blue>Going to the B2x10 series gets rid of that</font color=blue>
I think that going to the B2x10 series get's you more fender./w3tcompact/icons/smile.gif
Al
/ 7500 or 2410? #7
hey,
if you have the cash get the b2410. the b7500 in my opinion isnt much diff. than the bx2200 which im getting a new one next week. the b7500 has a little more hydrualic capacity than the bx and the tires are bigger but the b2410 has more hp and position control. i was like you kinda, i started out looking at the bx then the b7500 and even had thoughts of riding the b2410 thinkin the b7500 might not be big enuff, but HEY im not gonna be making my living with this thing and i have only 1+ acre. i will find some small side work though. anyway if you can afford it get the b2410 cause i dont think size will be a factor as far as manuevering. i have some steep mowing and knew any bigger than the bx would be too cumbersome.
rich
/ 7500 or 2410? #8
Al,
My apologies to your wife and her B7500. Nothing like having the real article in your garage or barn to verify these sort of things/w3tcompact/icons/smile.gif.
- Rob
/ 7500 or 2410? #10
Al,
Should have been clearer! My apologies. The plastic (as I recall....and I can't look in my garage like you /w3tcompact/icons/smile.gif)was a plate on top of the metal fenders that surrounded the lever controls. On the B2x10 series this plastic plate is metal. Certainly not a huge deal either way I wouldn't think.
Kevin
/ 7500 or 2410? #11
Rob,
No apologies necessary. I didn't send her to the barn to check this one out. If I had, thats where I would've spent the night./w3tcompact/icons/frown.gif She knew this one up front./w3tcompact/icons/smile.gif
Al
/ 7500 or 2410?
i started out looking at 7500 but the 2410 caught my eye, just liked the diff. in size and capacity. ended up buying a used 2400, with 68 hrs. runtime on it. have only used it a few times but i love it. if i did not find the used one i would have opted for new 2410 and paid the extra price. don;t think u will be sorry if u go to 2410.
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
UNUSED SDLANCH HYD DUMPER (A64280)
UNUSED SDLANCH HYD...
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
SKID STEER FORKS (A62613)
SKID STEER FORKS...
2022 EZ-GO ELITE...
2012 Ford E-450 Sewer Viewer Van (A61573)
2012 Ford E-450...
