Grading 74 front blade
/ 74 front blade #1
bud4410
kingsville, maryland
jd 3520 HST open station turf tires air seat jd 997 ztrak 72"
hi, does anyone have a 74 front blade on a 4310 or 4410? this is the full frame blade that mounts at 4 points under the tractor. my question is that i just mounted mine for the first time and the adjustable feet on the back of the blade are not flat on the ground but are tilted back at the top and foward at the bottom. i suspect that the mounting brackets could have been welded to the blade upside down. if anyone has one maybe they can tell me how theirs is. thanks for you time. bud
/ 74 front blade #2
I have a model 74 for my 4400. The skids do lean at a slight angle, say maybe 5 or 10 degrees. The top of mine are very slightly "forward" of the bottom. I can post a pic if you need one.
Wayne
/ 74 front blade #3
Here is a pic I hope
/ 74 front blade
hi wayne h, thanks for taking the time to post pics. i had it backwards in my original post. the tops of mine are also forward. i guess they are all that way. looks like if the brackets were reversed they would be straighter. i was able to sraighten mine by putting spacers in the indents at the top of the front of the shafts then securing with the set screws. i have a friend, joe riddebauer, spelling??? a helicopter guy but not RC. thanks again for your help. bud
2012 MERTZ ART. ARM MANIFOLD TRAILER (A67714)
2012 MERTZ ART...
2018 Ford Escape SUV (A66738)
2018 Ford Escape...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A66738)
2021 Mercedes-Benz...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
2021 PETERBILT 367 (A67714)
2021 PETERBILT 367...
2020 FORD F-150 XL CREW CAB TRUCK (A65054)
2020 FORD F-150 XL...
