732 bobcat no start
/ 732 bobcat no start #1
Kyjimblair
732 bobcat 231 Massey
I’ve read so many articles of no start for a Clark bobcat Ford engine , but I don’t read how they repaired the problem.
new points set at .025
New zenith carb
New plugs
New coil
Timing set at 12 btdc
Compression is low , but should at least try to start
(1)105
(2)80
(3)80
(4)75
/ 732 bobcat no start #2
Welcome to TBN. It takes fire, fuel and compression to run. You have already pointed out that it is low compression but it still should hit. You also said timing is set at 12 btdc so I assume you used a timing light to check that. If so, it must be firing.
This leaves fuel. Will it hit on some carburetor cleaner?
/ 732 bobcat no start #3
Are you SURE your point gap is correct? That sounds wide to me. How did you check your timing? If the gap is incorrect the timing will be a bit off. You can remove the plugs and put a small amount of oil in each cylinder to up the compression a bit. With a plug pulled and connected does it spark when the engine turns over? Is it getting fuel to the carburetor? Through the carburetor? Is the float set correctly? A shot of ether in the air intake should get some action if you're getting spark.
I turned the motor over by hand
Having an extra spark plug attached to the number one plug wire it fires as soon as it reaches 12 degree mark.
also it is on compression stroke on number one cylinder. Just before it reaches the top of cylinder.
also rotor is pointing to number one in the distributor.
it will not hit on carb cleaner.
Point gap is .025, new points and condenser from bobcat.
I have put oil in the cylinders , did not improve compression.
the spark is weak when cranking, but
Has a spark.
it could be wiring, when cranking the voltage should be more than the six volts while cranking.
I’m trying to find wiring diagram to the ignition and how it hooks up to the starter.
my bobcat don’t have these showing.
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2022 East Manufacturing 48ft. T/A Walking Floor Trailer (A64556)
2022 East...
2023 VOLVO L90H WHEEL LOADER (A64279)
2023 VOLVO L90H...
2016 JOHN DEER 5075M TRACTOR AND BUSH HOG (A66091)
2016 JOHN DEER...
2024 Ford Explorer SUV (A61574)
2024 Ford Explorer...
