7308 loader (bobcat style quik tach)
   / 7308 loader (bobcat style quik tach) #1
TOMLESCOEQUIP
Platinum Member
Strasburg, OH
Does any one use the quick attach on their 7308 ?? How about a price?? Aftermarket or NH ??
   / 7308 loader (bobcat style quik tach) #2
Have seen the quick attach for the 7308, I believe it was on Ebay from one of the NH dealers. Do not recall the price. Personally I would not go with the quick attach on the 7308 because of the weight of the quick attach and the limited lift ability of the loader itself.
   / 7308 loader (bobcat style quik tach) #5
Well since I viewed your message I guess I have to reply - your rules.
I would think adding the couple inches of forward would make the rear end lighter & reduce useful lift, as well as reducing lift by the #'s of the adaptor.
So, if I needed to switch buckets a lot & never had to max out my lift, I'd spend the money.
If I only switched buckets every month or so, and needed max lift out of my gravel pit all the time, i wouldn't waste the money.
If you could phrase your question with a bit more info, it would help to give you useful answers. How do you intend to use the loader?
I do not have one, because I only have the one bucket, & I need all the lift I can get out of the current setup.
--->Paul
As I fell into a good deal on the 7308 loader assy, I want to use it to take the place of a small skid-steer (NH LS120) at my home property that I use for multiple tasks. On the skidsteer, I have the std bucket, a pallet fork attachment,small cable plow, and a myers snow plow I cut down to 5' for the small skidsteer. Having the loader on then TC33 now eliminates the need for 2 separate machines & will take an extra engine powered machine out of the maintaince schedule. The LS120 skidsteer is rated to lift about 750# so I won't be giving up much lift by going to only the TC33. I'll probably sell the LS 120, and then get the quic-tach and a couple skidsteer attachments, as well as several blank plates for making up my own attachments from time to time.
   / 7308 loader (bobcat style quik tach) #7
If you have that many attachments & a skid steer, then I'd look for the adaptor as well.
On my 1720 NH tractor, I would not want to give up the lift force tho, as I tend to max it out as it is. I'm not sure what the lift force of that loader on a 33 is rated at/ going to be, just want you to be aware of that issue - if it is one for you. /forums/images/graemlins/smile.gif
--->Paul
What is the lift (weight) rating on the 7308 ?? The tractor is not going to be used every day for loader work, but will load & unload trucks & trailers with stuff on pallets, and an occaisional 55 gallon drum of fuel, & a few RR ties every now & then.
   / 7308 loader (bobcat style quik tach) #9
From my orginal brochure.
1320/1520/1620/1715 776#
1720 920#
1920 1020#
1530/1630/1725/1925 800#
   / 7308 loader (bobcat style quik tach) #10
TOMLESCOEQUIP,
When I bought my DX33 last year, I was in the process of building a new house. I also have the L130 loader (same as the 7308, just red). I wanted the quick attach bucket system so that I could use pallet forks to move brick around my house. My father is a bricklayer and we layed about 14,000 brick on my new home.
With the quick attach plate on the loader and the pallet forks attached, I could easily pick up 2 bands of brick, have them on the ends of my forks, and set them on the scaffold (6' high). (105 brick per band at roughly 3# per brick, times 2 bands = 630lbs) I could also pick up 3 bands (945lbs) about 12" high (no further) and move them where I wanted them. This made the rear end very light, and would not have been possible without front wheel assist and my 6" box blade on back.
I got the quick attach for the loader and a plate to adapt my bucket thrown in with the deal for the tractor. I did see the invoice though, and I think it was around $800~$900 total, for both pieces. The dealer got them from Kasco Manufacturing out of Shelbyville, Indiana. They did have a website (kascomfg.com), but I was just there and it does not seem to be working. You may ask your dealer if they are familiar with them though. I know when I was putting the deal together, I called Kasco and they don't sell directly to the consumer, you must go threw a dealer. I did talk to the engineer that designed the system though, and he was very helpful.
Needless to say, I love mine and I am glad I got it! /forums/images/graemlins/cool.gif
Hope that information helps,
CBox
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2012 Kenworth W900 (HEAVY DUTY) (A52748)
2012 Kenworth W900...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
Rogers 4th Axle (A51572)
Rogers 4th Axle...
