730 loader hydr pump
/ 730 loader hydr pump #1
MNSQUIRE
Stanchfield, MN
Ford Industerial 4000
I just replaced the pump shaft on my hydraulic pump for my 730 loader. Is there a right and wrong way to place the ring assy. when you put the pump back together?
/ 730 loader hydr pump #2
Pictures or a better description of which ring assembly you are referring to would be helpful. Pump model would also help narrow down the options.
thanks
Roy
/ 730 loader hydr pump #3
Might you be referring to the center section of the hydraulic pump of a Ford 730 Loader? If so, then yes. Match the pressure and return line connections of the loader.
Sorry. I have tried to put an attachment on but I am unable to do so. The numbers shown are from my parts book for Series 730 19-426 page 17. Book dates April 1965. PA-9369 on left corner of the pages.The pump consists of #13 Pump Cover(connects to output line and #1 Hydraulic Pump Cover(suction tube from the oil tank). The #7 Pump Cartridge Kit consists of the ring assy, rotor . The rotor contains 12 wanes #8. The rotor fits into the ring assemby but can go in four different ways. I seem to have the pump pumping in the wrong direction.
Thanks
/ 730 loader hydr pump #5
O.K. You have the original Vickers vane pump. As you view the center section (ring) you will see that on the intake (return) side the vanes can extend the maximum amount. On the opposite side (outlet/pressure) the vanes can extend the minimum amount. Orient the "ring" so the inlet is on the left side, as viewed in the direction of forward travel, and the outlet/pressure side is on the right (the same side as the loader control valve). You should be good to go.
Thanks you Sir. I have that picture in my mind. I will let you know the results. Thanks again.
/ 730 loader hydr pump #7
MNSQUIRE,
The cam ring (center section ) has a direction arrow on it,on the outside of the casting, that will show rotation of the input shaft.......flip the cam ring over 180 degrees to change direction.....:thumbsup:
Thank you Gentlemen. I got the pump to pump correctly now I have another problem. The pump drive shaft couplers slide towards the pump on the pump shaft and come out of the connection at the crank. I find no spacer or spring to hold the shafts into the crank connection in the parts book.
Thanks again for your help.
/ 730 loader hydr pump #9
A piece of pipe or tubing cut to size works.....
That's what I was thinking but was concerned about the spacer wearing down as the tractor side will be against the hub assembly as it turns and the outside against the pump housing the doesn't turn.
Okay got the thing fixed and working. I put a spacer inside the coupler hub from the tractor and the pump coupler. With the spacer against the end of the pump shaft and against the front of the drive coupler there is no wear as they turn as a unit. Again thanks for all your help. Now I hope at some point I will be able to pass on that help and help someone else.
MACK
/ 730 loader hydr pump #13
Just saw your post, I also have a 730 loader and I'mabout to install it on a 3000. There are 3 different lengths of driveshafts; you may need a longer shaft for your particular tractor. Make sure you use a high quality spline grease to prevent early wear on all of the splines. Do not use wheel bearing grease or any other typical grease. It will only heat up, turn to liquid, and get flung all over
213090 (A64276)
213090 (A64276)
2022 SANY SY5OU EXCAVATOR (A63276)
2022 SANY SY5OU...
2017 JOHN DEERE 317G SKID STEER (A65053)
2017 JOHN DEERE...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2023 ASV RT-25...
