7260 Air Filter Help?
/ 7260 Air Filter Help? #1
twiceborngypsy
I'm trying to find an aftermarket air filter for my 7260. Wix says #46387, but it's much too small. I understand that there is an early and later filter depending on tractor serial number, (mine is early). Any ideas?
Good news, I followed a lead on this board and the Kubota/Wix 46496 works perfect. Just drill out the hole on the metal end to match the wing bolt on the Cub and install the rubber gasket on the filter housing. $53 at the local auto parts, I'm sure better deals are out there. Goodby Mitsubishi air filter prices. I know the same filter will work on other 7000 series Cubs.
/ 7260 Air Filter Help? #3
$53 for an air filter?!? I'd be shop-vac-ing that one clean 'till it couldn't be shop vac'd anymore.
Joel
/ 7260 Air Filter Help? #6
I hope that fits on my 7532. Looks close enough to work. Thanks, you saved me some money!!!
I saw one internet dealer had his priced at $110+shipping. If your Cub uses a MA-10310511200 (a lot do), then the Kubota filter will work. Next time I'm going to call around to NAPA, etc., to cross over the WIX 46496 to their house brands. I was just happy this time around not to pay Cub prices. And yes JTKub, I blew the old filter out many times and milked it along as long as I could because of the ridiculous prices.
BTW: Pull the air vane off of your old filter and simply slide it in place on the WIX 46496.
/ 7260 Air Filter Help? #8
I believe my 5252 and the 3000 series tractors use the same deck wheels. Mine are delaminating (fronts) after three seasons. Cub wants $66 each + shipping. I found them on the web for $34. I believe that same wheel is used on a number of non Cub decks also.
They arrived today, I can see why they are pricey, they are roller bearing'd on the shaft and heavy. Sure hope they fit!
But $66 to $34, and somebody is still making money, even at $34!
Curt
2007 GMC C4500 Service Truck (A62679)
2007 GMC C4500...
1999 John Deere 5410 (A64126)
1999 John Deere...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
John Deere 7230 (A64126)
John Deere 7230...
Water Wagon (A64126)
