726 E snowblower
/ 726 E snowblower #1
mercury7
726 E snowblower
I bought a 726E John deere snowblower back in October 2009. Use it several times each season on my driveway only. Last week right when the blizzard ended i went to use it and the front auger would not turn, although the impeller and all shafts seemed to be turning just fine. I checked the belts, shear bolts, and all cables,,,, everything was fine.:confused:
I called the dealer who I purchased the blower from and he repeated the checklist to me, so the following day they came out and picked it up for service. he mentioned to me that sometimes the auger gear box goes bad,, OK.
Well this morning I get a call from the dealer telling me that the gearbox was indeed shot, but they found some thin copper wire wrapped around the inside of the side auger bracket, and this is the reason why the gearbox had failed.
The cost would be 400.00 to replace. Well I thought that the warranty would cover something, but he said no this would be considered an accident or misuse.
I am the type of person who changes the oil every season, oils and greases all fittings, waxes the shell, and adjusts the belts and springs. If I had seen some wire wrapped around the auger I would have had it cleared off asap.
It seems to me that this might be a design flaw, how could I have even seen it if it was wrapped ??
Your opinions would be greatly appreciated, !
/ 726 E snowblower #2
I am just like and do all that stuff to my machine as well but ether the dealer is bull****ing you and found another problem and just did not want to say he was wrong and wants to make a some extra money or he is tell the truth because some times there are thin strings of wire in side the gasket that seal the gear box and something you caught when you were snow blowing broke and got stuck in the gear box but still if a piece of wire got caught in your gear box it would have stop everything and even maybe broke a belt. But in my opine he is bull ****ing you just to make some money.
/ 726 E snowblower #3
So would I and it's wired because those gears are sold carbon steel.
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
Pat's QH and hydraulic top-link.
Pat's QH and...
2012 Toro Z Master Professional 72in Zero Turn Mower (A61572)
2012 Toro Z Master...
iDrive TDS-2010H...
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
2006 GMC C5500 4X2 BUCKET TRUCK (A59912)
2006 GMC C5500 4X2...
